Question about HP Pavilion zd8000 Notebook
HP Pavilion zd8000 got my first horizontal line.
I unplugged it until I know what to do. I have to much important stuff I can't afford to lose until I figure out what I can do.
  • 3 Answers
A horizontal line on your LCD display is either caused by the video chip on your system board or the LCD screen itself. Either way it will not cause you to lose data on your hard drive. It is a video problem.
By connecting an external monitor from a desktop PC to the back or side of your notebook and switching to it by using your function keys (see manual), you can see if the problem is also on the monitor (meaning video chip problem) or stays only on the notebook LCD (LCD problem).
The video chip problem means you will need a system board. The LCD problem means you will need a new LCD panel. In rare cases, reseating of the ribbon cable on the back of the LCD panel will fix the red line.
Posted on Jun 18, 2009
  • 244 Answers
Horizontal black line on monitor.....
You won't loose any information, but your monitor is telling you that is has problems and eventually fail and need a replacement.
If you don't carry the laptop to different places, you can get away with a regular monitor, by connecting it to the VGA video adapter on your laptop....
Hope this helps
Please don't forget to rate if answer is useful
    President:
  • 2,653 Answers
You won't lose your information. That's on the hard drive.
The computer will work fine the mean time. That line is just a small component dying on the lcd board in the lcd itself.
You can fix it by swapping the lcd with another one.
That's it.
If you're worried about losing your important files.
BACK THEM UP!
Pinky red tinge horizontal lines near the taskbar in display HP Pavilion dv4
sounds like your power inverter is going bad. replace power inverter and see how that works. Other issue if not solved is probably lcd screen. Inverter's can be found cheaper used if you use the serial number on your old inverter for searching, seeing as how inverters are often used on many different of machines. FYI.
Mar 13, 2010 | HP Pavilion zd8000 Notebook
Problems with HP Pavilion zd8000 PC Notebook? vertical lines appear on screen
Your screen has a faulty connection you will have to replace the screen.
Feb 22, 2010 | HP Pavilion zd8000 Notebook
I have a purple line about 2inch thick horizontal through my screen
Tricky one as it could be one of several possibilities.
Faulty mobo.
Video driver corrupt / try reloading vid driver off manufacturers site.
Faulty monitor or associated components.
Dec 22, 2009 | HP Pavilion zd8000 Notebook
I have a HP laptop model Pavilion ZD8000 and I want to
The specs for the ZD8000 says it supports up to
1GB DDR2 SDRAM 400MHz
Jun 28, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000
You may be able to buy a replacement LCD from
www.laptoppartsonline.com
Feb 12, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
HP pavilion zd8000 start-up problem.
Try to unplug all the PCI cards and boot, if its still doing it check the ram. If its still doing it check to see if the power supply is good. If all that fails, It could be eather a bad mother board or bad processor.
Oct 03, 2008 | HP Pavilion zd8000 Notebook
Hp pavilion f1523 lcd monitor
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Oct 02, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 Manuals
Hi, the manual is available in FixYa itself.
The link is http://www.fixya.com/support/p381158-hp_pavilion_zd8000_pf456av_pc_notebook/manual-3309
One external link is
http://www.onlinefreeebooks.net/?s=Maintenance+and+Service+Guide+HP+Pavilion+zd8000+Notebook+PC.pdf+
May 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
352 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
