Question about Casio Collectible Tv-400 2" Lcd Color Packet Portable Television Ntsc 6v Japan
Can't get a picture
I have put in new batteries and just can't get a picture. Even when I plug it in.
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
I put in new batteries...the camera works fine for four or five pictures and then the battery message comes on that I need new batteries. Sometimes that message comes on before I even get to take a...
Same here, not the batteries
1.2v rechargeable Radioshack 1600mah & 1500mah did work though...
If you eventually get it to boot, go to menu and pick coolpix batteries.
Apr 07, 2011 | Nikon COOLPIX L20 Digital Camera
Won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 17, 2009 | Pentax K100D Digital Camera
I keep getting "Battery Exhausted" messages, with new batteries
you have to use only very good quality batteries ...I have a philips..and if I do not put alcaline quality bateries in it ..it do not even power up ....and even with this expensive ones it eats 'em like snacks...
by the way ...keep the batteries inside only when you shoot cause all this new cameras with display and so ...consumes the batteries even when they are powered off ..
my advise is to buy some accumulators the kind you charge on the home power plug.....so in this way .. you will always have strong power into them ..and the cost its worthily ..
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Camera does not switch on, even though new batteries have been put in it
Is the new battery fully charged?
You mean no lights at all even a quick blink on any other light when you switch it on?
Did you plug the battery in correct way? (I guess it wont fit if its the other way around :-) but there are batteries that doesn't have keyway and they fit exactly even if they are plugged in incorrectly meaning their connectors doesn't reach)
Contact the vendor or manufacturer of your camera if its still under warranty.
May 05, 2008 | Cameras
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Casio Collectible Tv-400 2" Lcd Color Packet Portable Television Ntsc 6v Japan Logo
29 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
