Question about KitchenAid 24 in. KUDI01DL - Multiple Color Built-in Dishwasher
Kudi01dl heater circuit
Circuit braker faulty
The following link is step-by-step troubleshoot for water heater electric circuit:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Link also tells how to test breaker inside main breaker box, and then ends with step-by-step troubleshoot for internal electric water heater parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
See basic water heater circuit on following link:
http://waterheatertimer.org/240-v-water-heater-circuit.html
If circuit breaker is bad, following link shows how to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Jan 11, 2011 | RELIANCE ELECTRIC WATER HEATER
05 dodge cummins,driving down roadway ,throttle will climb erratically for about 3-4 seconds when coming to a stop, it has electrical throttle connections ,no cables that i can see. When parked idling and...
To retrieve OBDII Error codes from your Chrysler/Jeep/Dodge vehicle, do the following sequence with the key: ON-ACC-ON-ACC-ON and look at the odometer, that is where codes will be displayed. Here are the codes that you may/can get.
Ho2S = heated oxyen sensor, TP = throttle position, MAF = mass airflow, MAP = manifold absolute pressure, TC=turbocharger.
P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1
P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
P0050 HO2S Heater Circuit Bank 2 Sensor 1
P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1
P0056 HO2S Heater Circuit Bank 2 Sensor 2
P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2
P0100 MAF Sensor Ckt. Insufficient Activity
P0101 Mass Air Flow (MAF) Sensor Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0104 Mass Air Flow Circuit Intermittent
P0105 MAP Sensor Circuit Insufficient Activity
P0106 Manifold Absolute Pressure (MAP) System Performance
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0109 Manifold Absolute Pressure Circuit Intermittent
P0110 Intake Air Temperature (IAT) Sensor Circuit
P0111 Intake Air Temperature (IAT) Sensor Performance
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature (ECT) Sensor Circuit
P0116 Engine Coolant Temperature (ECT) Sensor Performance
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position System Performance
P0121 Throttle Position Sensor Circuit Insufficient Activity
P0122 Throttle Position (TP) Sensor Circuit Low Voltage
P0123 Throttle Position (TP) Sensor Circuit High Voltage
P0124 Throttle Position Sensor 1 Circuit Intermittent
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0126 Insufficient Engine Coolant Temperature for Stable Operation
P0128 Coolant Thermostat
P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
P0133 HO2S Slow Response Bank 1 Sensor 1
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 HO2S Heater Performance Bank 1 Sensor 1
P0136 HO2S Circuit Bank 1 Sensor 2
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0139 HO2S Slow Response Bank 1 Sensor 2
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 HO2S Heater Performance Bank 1 Sensor 2
P0142 HO2S Circuit Bank 1 Sensor 3
P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response
P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
P0147 HO2S Heater Performance Bank 1 Sensor 3
P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
P0150 HO2S Circuit Bank 2 Sensor 1
P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
P0153 HO2S Slow Response Bank 2 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0156 HO2S Circuit Bank 2 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0159 HO2S Slow Response Bank 2 Sensor 2
P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 HO2S Heater Performance Bank 2 Sensor 2
P0162 HO2S Circuit Bank 2 Sensor 3
P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage
P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage
P
Dec 18, 2010 | 2005 Dodge Ram 2500 Truck
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
My kitchenaid KUDI01DL dishwasher began making a lot of noise while running, then subsequently decided not to circulate the water around to wash the dishes. It sounds like the motor is running (maybe) but...
The problem is very likely in the chopper and/or somewhat possible in the impeller. The chopper is replaceable from the front. Disassemble the pump, the chopper will be on its left side under a cover. That cover is kinda tricky to remove (remove all torx screws you can find, push the thingy on the top of cover with flat screwdriver to the right, slightly pulling it up).
The impeller used to be a replaceable part, and is no longer available separately, so you'd have to replace the whole motor assembly. To get to it - pull dishwasher out and lay it down on its back (or on its side, if there's no water in it)
Chopper
Motor
Mar 29, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
I have my check engine light on my 2003 Ford F150 supercrew truck, with 141000 mil, engine is the v8 4.9L my temp gauge pegs out to the hot when i drive a bit and the engine light comes on i am told its a...
here are all poss causes of check engine light.
Generic Trouble Codes
P0001-P0099 – Fuel and Air Metering and Auxiliary Emission Controls
Code Description
P0001 Fuel Volume Regulator Control Circuit/Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0005 Fuel Shutoff Valve Control Circuit/Open
P0006 Fuel Shutoff Valve Control Circuit Low
P0007 Fuel Shutoff Valve Control Circuit High
P0008 Engine Position System Performance (Bank 1)
P0009 Engine Position System Performance (Bank 2)
P0010 A Camshaft Position Actuator Circuit (Bank 1)
P0011 A Camshaft Position - Timing Over - Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing Over - Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank 1)
P0014 B Camshaft Position - Timing Over - Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing Over - Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over - Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over - Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing Over - Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 MAP/MAF - Throttle Position Correlation
P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low
P0073 Ambient Air Temperature Sensor Circuit High
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0090 Fuel Pressure Regulator 1 Control Circuit
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0093 Fuel System Leak Detected - Large Leak
P0094 Fuel System Leak Detected - Small Leak
P0095 Intake Air Temperature Sensor 2 Circuit
P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
Dec 01, 2009 | 2003 Ford F150 Regular Cab
My check engine light has come on in my 2006 Pontiac G6 after 2 and a half years. What could possibly be wrong since I keep my car serviced and the guys had just told me that my car was in tip top shape?
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
Jun 25, 2009 | 2006 Pontiac G6
1992 Buick Park Ave Engine light somes on intermittently. Goes out When you increase RPM pass 1500 or decellerate below 1000. Thanks! Dave
THIS LIGHT IS TURNED ON BY ONE OF WELL OVER 200 DIFFERENT PROBLEMS IN THE ELECTRONIC CONTROLS OF THE ENGINE. TRANSMISSION OR EMISSION CONTROL SYSTEM, IN ORDER TO HAVE ANY HOPE OF FINDING THE ROOT CAUSE THE DEALER MUST TEST THE SYSTEM WITH A SPECIAL SCANNER TO SEE WHAT TROUBLE CODES ARE PRESENT, BELOW U WILL FIND A PARTIAL LIST OF THE FAULTS THAT CAN BE PRESENT WHENEVER THE LIGHT IS ON..
Jun 24, 2009 | 1992 Buick Park Avenue
2005 Neon engine light came on and stays on. Car drives okay. Has around 34,000 miles. No other problems
Take it to Autozone or Advanced auto and get an engine diagnostic and ask them to printout the results. Most times it's a sensor.
Jun 05, 2009 | 1996 Dodge Neon
Open Questions:
See all KitchenAid 24 in. KUDI01DL - Multiple Color Questions
KitchenAid 24 in. KUDI01DL - Multiple Color Built-in Dishwasher Logo
15 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
