Question about Homelite Mighty Lite Lawn Trimmer
How do i adjust carbuerator
Will only stay running with engine gunned after starting in full choke then switching to half choke. Dies w/ no choke
    Scholar:
  • 81 Answers
Start your adjustment by turning both screws (gas and air) all the way in and then back them out one and a fourth turn. Start from there. Hope this helps.
Posted on Jun 19, 2009
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Engine will start but only run at choke or half choke and low throttle sputteres and or dies if you try to increase to full throttle and dies if you take off choke
Sounds like fuel starvation. Check for plugged fuel filter or sediment or dirt in the fuel tank. Failing that, examine the carburetor for dirt/sedment plugging it. Good luck!
Oct 14, 2010 | V-Twin Horizontal OHV Engine with Electric...
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Won't start, can't remember starting procedures and dont have manual
Make sure the fuel valve is on. Generally that means pointing down inless there is a diagram on it.
Turn the switch on.
Pull the choke on the carbuerator on full. There will be a picture of a butterfly valve set it so that it is closed. Pull the cord till the engine fires. let it sputter for a second, then open the choke. If the engine dies right away, do all of the above again but once it fires, only open the choke half way. once it warms up a bit open the choke completely.
Dec 22, 2009 | Honda Pressure Washer PSI 3000
My weed eater blower starts and i can run the engine at full
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Jul 18, 2009 | Poulan Garden
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
506 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
