Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid stand mixer head locking mechanism
  • 118 Answers
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
Posted on Nov 30, 2008
SOURCE: Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Posted on Mar 01, 2009
ricardok45
  • 135 Answers
SOURCE: Kitchenaid stand mixer oil leak
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
Posted on Mar 06, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Posted on Jul 08, 2009
  • 130 Answers
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
Where is the Height Adjustment Screw on the KitchenAid K45SS Classic Stand Mixer? rcherbig0417@gmail.com
It is in the front middle of the hinge area, visible with head raised. Clockwise to lower and anti clockwise to raise. Head height is set with flat paddle to just clear the bottom of the bowl when head is locked down.
May 25, 2014 | KitchenAid K45SS Classic Stand Mixer
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
KITCHENAID LOCK IS GETTING STUCK AND MIXER IS CLUNKING
I am having the same problem. The head wiggles when beating and the blade is getting worn on the bottom, protective cover is getting worn off by hitting bottom of bowl. I have to wiggle the head in order for the head to lock in place. thanks for any help - Diana
Jan 11, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer K45SS willnot tilt the head I do not understand How to fix this problem
Put a towel on the bench and put it upside down on the towel. Wriggle lever and pedestal about and it may free up. The lever may be disengaged from the locking mechanism. The machine will need to come apart to fix any mechanism lever problems.
Aug 16, 2013 | Food Mixers
I have a Kitchenaid Artisan stand mixer and the head is loose. When in the down, locked position, I can move it up and down by probably an inch. I've been into shops and tried to do the same with
If you have also tightened up the screw that you can see from the front in the middle where the hinge pivots when head us up then that's where your problem is. That is the head height adjustment and is to set the flat paddle to just clear the bowl when the head is down.
Aug 01, 2017 | KitchenAid Artisan Series Tilt-Head Stand...
Motor head locking lever is hard to unlock on Kitchenaid mixer after kneading dough.
Hello Flyfishing19,
The problem that you are experiencing is due to the torque that is put on the head while mixing dough. The lock is still working fine, although it is getting wear. You can replace the locking mechanism. However, it will work for a while longer. If you want to change the mechanism post back to this thread and I will be happy to locate you one and explain how to change it.
Mar 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
KichenAid mixer parts problem
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
has a diagram of the locking mechanism item 9. The screw you removed was probably item 8. Look at the parts and you should be able to figure out how to get it back together.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid mixer. Top is loose so it bounces when
Hi MJANKOW520. I?m going to assume your KA mixer is a ?Tilt-Head? mixer. You don?t say specifically. Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and need to be readjusted (or repaired) for it to keep your mixer head stationery. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select the file listed under Parts List (check to see it this matches your mixer model). This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part name and numbers. Turn to page3, titled: Base and Pedestal Unit. You?ll want to focus on Illus. #9, Link & Lever Latch assembly, which locks the mixer head to the pedestal when run your mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid K45SS Classic Stand Mixer
Hope this helps!
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
80 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
