Drills / Drivers
Problem for Drills / Drivers
Generic problem for all Drills / Drivers
My Delta 18.0 volt battery charger does not...
By dnminlv on Jun 18, 2009
I have a Delta shopmaster wood workers kit. I have not used it that much and when I went to charge the battery I noticed it would not charge. I tried to diagnose the electronic problem (along with a friend who fixes this stuff) and the cause of the problem was indeterminable because we had no schematic of what we were supposed to read on the ouput. There is power but when you plug in the battery it disappears.
Solution #1
posted on Sep 26, 2009
Not Rated)
GodExpects
Rank: Apprentice
Rating: 0%, 0 votes
Carefully take the charger apart - I had the same problem - use an allan wrench to take the charger apart - and on the circuit board is a fuse 4A 250 volt - my was blown - replace it and it should work - mine blew most likely from either water or dropping it. You have to carefully remove the fuse - they have tried to glue it in place but it will come out of the holder and the new one will go in easily.
Dan
Was this helpful?
Yes
No
Solution #2
posted on Jun 18, 2009
Not Rated)
smjdragonfly
Rank: Guru
Rating: 88%, 74 votes
Using a voltmeter on DC check the pos and neg terminals in the charger. It should read more than what the battery is rated if its quick charge. If not, it should read slightly lower than 18. If so, it sounds like the battery is bad. How old is it? DeWalt/PC/Delta has a pretty good warranty program. Lemme know. Please rate me
Was this helpful?
Yes
No
Popular Solutions for Drills / Drivers
Questions and Unsolved Problems for Drills / Drivers
Answer
what is the best impact driver
Answer
Ordered new gear train for my PS20. Does it have to "bolt on" to the motor or is it held... (More)
Answer
Looking for a n owners manual for Chrftsman nextec 12 volt lithium-ion drill/driver and Multi-saw
Answer
where to find replacement power switch for craftsman 18 volt drill
Answer
how to change brushers in makita hr 2020 110volt sds drill
Describe your Drills / Drivers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Drills / Driver Experts
Top Garden & Power Tool Repairmen
in Newport, KY
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
