Question about Pride Mobility Products Pride Victory 10 - Three Wheel
Transaxle noise grinding noise
  • Pride Mobili... Master
  • 1,263 Answers
Hi , normally this can be a bearing running dry or a worn bearing ballrace ..... is it possible to get one off the floor so it will spin... please take great care when carrying this out... running the scooter like this will allow to pinpoint where the noise is coming from...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Feb 05, 2015
There is a grinding noise when i make a sudden stop or go in reverse.its a hydrostatic transmission
ck and clean off the cooling fan on top of transaxle sometimes grass and leaves get up there and make funny noises also you can ck oil level in transaxle for proper fill level
Nov 11, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Windstar transmission
Failed Transaxle
Very common on that vehicle
Get something else,preferably
not a transaxle
Jan 17, 2013 | 2003 Ford Windstar
Jetta making grinding noises and not moving, but speedo goes up.
check your half-shafts going from the transaxle to the wheel hubs. I suspect that one of them has broken off.
Aug 05, 2012 | 2002 Volkswagen Jetta TDI
88sedandeville, something snapped in transaxle or rh axle, just makes strange whirring grind noise. Is it drive chain or axle? Should I just get another trans?
make sure the axle joint didn't fail then on the pass side of the car behind the axle there is a cover that houses the differential open that and check the gears in there
Jul 07, 2012 | 1988 Cadillac Sedan DeVille
2006 chevy cobalt transaxle noise , i blocked car up remove both front wheels started engine, engaged transmission to drive, listened to noise sounded a bit like a grumbling/grinding noise., no fluid leaks...
WORN FRONT BRAKE PADS WILL MAKE GRINDING NOISE IF PAD WORN DOWN TO RIVETS RUBBING AGAINST BRAKE ROTOR WILL MAKE GRINDING NOISE, IF BRAKE PADS OKAY WORN DAMAGE DRIVE SPROCKET SUPPORT BEARING .
Oct 25, 2011 | 2006 Chevrolet Cobalt
When I was driving my 1996 Geo Prizm at around 25mph, I heard a popping sound and then the grinding started like it was rubbing metal to metal. When I turn to the right, it sounds louder. I had the brakes...
CV Joint went out. since it gets worse when you turn right it is most likely an inside drivers side CV joint or the out side passenger side. The popping sounds was probably the dust boot popping from pressure build up which should make it simple to locate since you just need to identify the boot with a tear in it.
Feb 28, 2011 | 1996 Geo Prizm
Grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Jul 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
2002 Mazda 626 clip on end of transaxle fell off and is grinding
you could pop the axle out and get a flexible magnet hopefully it is in a place the magnet can get to,have a good day DB
Feb 04, 2009 | 2002 Mazda Tribute
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
126 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
