Question about Acer AL1715 17" LCD Monitor
Monitor acer lcd AL1717a
When i plug the monitor to ac line this power on and show acer in the screen and the screen is dark and have a gray rectangle the imagen is present but is too dark
  • avega209 Jun 18, 2009
    i forget to say that the buttoms of the monitor doesnt work it doesnt anything push the power bootom and not do anything
  • 244 Answers
Looks like you have a burned lamp.
Most LCDs have a lamp that lights the screen's image.
If you see the image, but its too dark.....you need a lamp replacement.
Please rate this answer if its useful
Posted on Jun 18, 2009
If the Acer splash screen shows up, how can the bulb be to blame? I've known plenty of parts that will work intermittenly, but I don't recall any type of bulb to illuminate for only a few seconds and then go dark, only to repeat the cycle when turned off and on again. I also have this same problem with my AL1715...I guess another thing to add is that it always seems to happen after the 'auto-config' is finished doing what it does. That may be the grey rectangle that he mentioned originally. Could there be something else to blame?
FYI - I did check all the caps and their tops are nice n' flat.
Posted on Jul 09, 2009
  • 78 Answers
Sounds a backlight problem one of the lamps are broken
Posted on Jun 20, 2009
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
The lights come on but nobodys home, i get a dark gray screen, it trys to to start then stops the lights stay on
Try plugging your laptop into a desktop monitor to determine if it's a display problem or goes deeper than that.
Dec 24, 2009 | Acer Aspire 4720 Notebook
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
My acer monitor is not turning on please help i have try evrything
have you try replacing the power cord of your LCD monitor? mybe its defective or not properly plug to an AC outlet. check also the source of your power if its working....it from AC outlet there is a voltage present try to replace your power cord connected to your monitor with a new one
Oct 10, 2009 | Acer AL1923 19" Monitor
My acer monitor
I have answered this in other threads but to reiterate....
The Gray rectangle "No Signal" I use a Power Strip and Turn off as soon as it cycles back to Normal screen. It is so much easier then to unplug and Plug back in when it does happen.
As for the Newer Problem(s) and I too have had mine for only couple of years... Copied from Previous post
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Feb 02, 2009 | Acer X241Wsd Monitor
Lines on the Screen
2 possibilities video card is damaged and bleeding ac power from the motherboard or the motherboard is damaged from a power spike and is bleeding ac power into the video card(this would be my best guess based on yur description). that is the best i can do on this info you have given I recommend you take it in to a service center for a definitive answer.
Jul 22, 2008 | Acer X221WSD Monitor
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
742 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
