Question about Tivoli Audio Players & Recorders
Remote is stuck - Tivoli Audio Players & Recorders
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Tip
Harmony remote stuck on "Welcome to Tour Remote"
Hi people. Yeah the title should say 'Welcome to Your Remote' my bad haha.
This message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware.
3. Update the remote.
If that doesnt fix it then it is more than likely a hardware issue.
on Mar 14, 2010 | Audio Players & Recorders
Logitech Harmony 520 stuck in safe mode
Use the solution provided at http://www.fixya.com/support/t5148847-not_functioning_message_showing_welcome
Probably a stuck button.
It worked for me.
Jul 05, 2010 | Logitech Harmony 520 LCD Remote Control
Remote control not functioning.message on screen says welcome to your remote
Hi. This error message indicates that there is a button on your remote that is stuck down. Please do the following to get your remote working again: 1. Remove the battery from the remote.
2. Push in, and massage each button to ensure that it is not stuck down.
3. Replace the battery, and connect the remote to your computer.
4. Click 'Update Remote.'
Jun 23, 2010 | Logitech Harmony 550 Remote Control
Not functioning,message showing welcome to remote
Jun 23, 2010 | Logitech Harmony 520 LCD Remote Control
When I turn on my unit the display is stuck with REMOTE ON
Move the remote to another room to test. It is possible a button on the remote is stuck on.
Beyond that , it probably needs to go in for service.
May 16, 2010 | Sony CDP-CX400 400-Disc CD Changer
My Harmony remote come us and is stuck at the welcome screen, I have replaced batteries, and I am able to update config off of my PC, but the remote only comes up to welcome screen and no buttons are...
This message means that there is a button that is stuck down on the remote. All you need to do is un stick it!
2. push in and massage each button to ensure it is not stuck down.
3. Put the battery back in, update the firmware.
4. Update the remote.
Hope that helps you out
Apr 21, 2010 | Logitech Harmony 360 LCD Remote Control
Remote is stuck in Safe Mode. How do I get it to
Connect the remote to your computer and log in. Go to the remote settings section and "update firmware". This should fix the problem.
Feb 19, 2010 | Logitech Harmony 550 Remote Control
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
2. Put the battery back in, update the firmware,
That should get the remote working again. :)
Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
Open Questions:
26 people viewed this question
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
KC135Nav
Level 1 Expert
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
