Question about Toshiba CT-90326 Remote Control
Two months old tv as of today remote wont work why?
Remote has new batts, still not working?
3 Suggested Answers
  • 81 Answers
SOURCE: intermittant remote
yes they do go bad. try cleaning the inside of the remote and check for a bad solder connection with-in the remote. the key pad can get dirty from your handling maybe a good cleaning but do not scrub it just lightly touch the pad with cue tip and alcohol
Posted on Mar 20, 2007
  • 360 Answers
SOURCE: Remote Control wont open manue on new tv
ensure the satellite receiver is turned on and the output from the satellite receiver is connected to the ant. in on the tv. on the remote control, press the tv button, then the menu button. from the menu, select settings, set input to ant. .
do this and let me know what happens so we can get this working
I will be available till 2:00am CST
clarkco
Posted on Feb 16, 2009
I have an old Zenith T.V. that works perfectly except that it can not be controlled by the brand new remote I bought. It appears that the T.V. does not respond to the remote. The remote has codes for...
If you have tried all the codes for the tv, and none of them work, the tv might be too old to respond to the newer remotes. Check that the batteries are inserted properly into the remote.
Some older tvs are just not compatible with todays systems.
May 27, 2011 | Televison & Video
My remote dose not work. I Have had it for only 2 months!!! 1:Checked voltage on batts both read 1.67v 2:Cable company tech said eye on TV is defective.
Tv only bought for 2 months,no way the the tv IR board dies that fast.The tv remote CPU is shorted and dead.The remote is the problems.Call Proscan customers service,talk to them get ur warrenty at work.Tell them u need another tv remote.Might have to send their old remote back.
Oct 25, 2010 | Proscan 40LD45Q TV
Remote quit working, batts new and no obstruction to IR signal?
A remote wears out far more faster than the device it controls (the sweat from your palms is highly corrosive). Nothing you can do, just buy a new one.
Jun 08, 2010 | Televison & Video
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
Universal remote
make sure the batt. is good, pount the remote @ tv, then select the program button, or setup, then select the tv, then select the on-off button till tv turns on then select setup
Feb 13, 2010 | Televison & Video
My family just bought the dynex 1080 from best buy saturday and today myfather can't even get the controller to get the volume to higher or lower or can't even get the tv to turn on or off what is the...
TAKE IT BACK!!! If you can. Many problems w/Dynex.Esp. Now they are no longer in business.
You can not get parts for them.Your remote problem may be a stuck button.Try pushing each button.Sometimes the rubber sticks if the remote is new.Battery may be bad or not making good contact.Take the batt.cover off and roll the batts. Also take the batts.out and push the buttons on the remote,then replace the batts.some times that works.But if you can take it back to Best Buy.And get another TV. Stay away from off brands. Also RCA are junk,not the same compant. I have too many in the shop to count even if I count with my toes. Samsung ,also Vizeo great for the price."basicly a lower end of LG"If you can't fine a decent priced TV at Best Buy,Try Wal Mart. But on all these new TV's,you need to buy the warenty.They still have alot of bugs to work out.That is about 98% of my business.Doing the warenty repairs in central FL.
I hope this helps you out. todd
Oct 27, 2009 | Dynex DX-LCD37 TV
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Dec 10, 2008 | JVC LT-26X575 26 in. LCD HDTV
Plez help
Have problem with my 2-month old Wii. Please see whether you can offer any suggestions. My problem is: Red light comes on no problem when power is connected, but when pushing the power button nothing happens - no green light? is this a sync problem? this happened yesterday and i unplugged everything and when reconnected it worked, but not today? have just installed a new tv, could there be interference from the new remote?
Jan 31, 2008 | Nintendo Wii Console
Toshiba CT-90326 Remote Control Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
