Question about Maytag Dishwashers
Glasses do not get cleaned
Glasses and top shelf items have debris stuck on them that was not there when loaded
  • 6,784 Answers
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Jun 18, 2009
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
I have a built in Electrolux ESL624 in the house I've just moved in to. I have noticed that items placed on the top shelf like glasses and cups are not always cleaning properly. Black deposits are being...
Check the spray arms are not clogged as well as the top one take off the bottom one clear a hole underneath the arm. make sure the arms can turn freely. dishwasher fresheners hanging on the basket can stop the arm turning. clean the filter in the bottom. Is the machine heating it should be hot at the prog end.
Aug 04, 2010 | Electrolux 23 in. ESL624 Built-in...
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
181 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
