Question about Black & Decker HS80 Rice Cooker
Will not boil
Only warms does not boil
How do I cook crab legs for how long
  1. 1 Fill large stockpot or Dutch oven half full with water; add seafood seasoning and salt. Heat to boiling.
  2. 2 Add crab legs. Cook 3 to 5 minutes or just until heated. Remove with tongs to serving platter. Serve warm with melted butter.
Boiled Crab Legs recipe from Betty Crocker
www.bettycrocker.com/recipes/boiled-crab-legs/57fa96aa-ea80-4cf9-86d4-df935690b683 How do cook crab legs for how long Google Search
Dec 22, 2016 | Cars & Trucks
I cannot take off the lid of the Pro chef and manual is unclear. How do I unlatch it?
Manual Pro Chef PU 100
I have received the hot water boiler, but it does not stop boiling the water. Instead of going to "Keep Warm", the machine continues to boil the water indefinitely. We left the boiler on and came back after 2 hours, and it didn't stop heating the water. Therefore, I refilled the boiled, turned off the machine, unplugged it, plugged it back in, and then turned it back on. The water continues to boil without going to "Keep Warm". I require a solution to the issue or a replacement as soon as possible.
Apr 25, 2014 | Le Chef Electric Shabbos Hot Water...
My 99 dodge durange heat take a while to heat up
It's not a pump problem. Check the thermostat and coolant flow through the heater itself.
Jan 18, 2018 | 1999 Dodge Durango
When i turn on the heat it smell like coolant
Your heater core is leaking anti-boil into the cabin. Either the core or the connections to the core are broken. CAUTION: Anti-boil is poisonous. Whenever working on the system take great care to keep it off your skin and do not allow it to puddle anywhere as dogs and cats are attracted to it as it has a sweet smell. Also, do not work on the system when it is hot as it can cause burns.
Drain anti-boil (wait until car is cool!!) and pull the core. It is located in the HVAC system, bottom right side. You will need to remove a substantial quantity of interior components to do this. Be prepared for some coolant spillage as you remove the core.
Using new hose clamps, install the new heater core, ensuring all connections are secure. Install any previously-removed interior/HVAC components or covers.
Refill the anti-boil through the overflow bottle, leaving the cap off. With the heater set to max heat, start the car, and allow to warm to normal operating temperature. Now slowly fill in the coolant to the specified level until the system is free from air bubbles. Install the cap.
Stop the engine and allow it to cool. Remove the cap slowly, allowing any residual air pressure to be released. Top up the anti-boil as needed, again leaving the cap off. Start the engine and allow it to warm to normal operating temperature. Top up anti-boil again, slowly to eliminate any air bubbles.
You may need to repeat this procedure two or three times until all air is purged from the system.
Oct 17, 2013 | 1999 Volvo V70
Kettle keeps turning off before it is boiled
Sounds like the thermostat has gone out of calibration. If you're handy with appliance repair it might be possible to purchase (internet) and replace that part - they're usually not adjustable. Otherwise it's a new kettle.
Mar 01, 2018 | Morphy Richards Kitchen Appliances -...
Should the top of the range get too hot to touch when boiling water
The eye you have on to boil the water will get too hot to touch but the rest of the surface should not get warm.
May 12, 2010 | Frigidaire Kitchen Ranges
Water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Nov 29, 2008 | Kitchen Appliances - Others
Use of warm water
Warm water is said to contain more impurities than cold water, like lead. Warm water takes more lead from your home plumbing, than cold water.
So it's not advised to use warm water for boiling...
Mar 27, 2008 | West Bend 13500 Coffee Maker
Black & Decker HS80 Rice Cooker Logo
29 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
