I have a tempstar unit on the insixea nd a thermol zone on the outside are yh ese units compatable
  • 306 Answers
SOURCE: ac unit does not turn on
If you have to physically hold it in? Then your coil is bad on the contactor. Need new one. You need to test the compressor ohm it out make sure it is still good. Check your capacitor also. It starts to get a little involved so if you are not real comfortable with this might have to call in a tech. But if you need some help just ask can walk you through this step by step.
Posted on Jul 27, 2009
SOURCE: Need info. on a Tempstar Comfort 2000 unit.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
Posted on Sep 01, 2009
ryanmalin
  • 40 Answers
SOURCE: tempstar central air conditioner The AC unit is
check to see if you have a safety cut off switch installed on your inside unit's drain line. if so, pull it out or unscrew it they are easy to access the little float switch that will cut your unit off if the drain line is clogged.
most of the time this is the cause of a unit not doing anything at all.
if this does not work the next step, if nothing is happening at all, is to open the inside unit and check for control voltage (24v).
Posted on Oct 10, 2009
SOURCE: 1004 tempstar a/c air quits blowing into house
Recently bought the same unit, new but was in storage for several years. Looking for the original list price for the unit itself, so I dont take any losses financially. If and when I do find out, Ill be willing to sell any parts you need to fix your system.
Posted on Dec 28, 2009
  • 82 Answers
SOURCE: i need a wiring diagram for a tempstar gas pack
Go here - http://www.gotempstar.com/go/index.asp?t=86&s=477
enter PGAA in model box.
Posted on Mar 14, 2010
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
I have a tempstar central heat and air unit and i need a wire diagram for a model pa5548aka4.
my tempstar central a/c unit will not get above 80 degrees during the day, the charge is fine so we are told, we noticed that the coils and fins are filthy and we have done everything to try to clean it out with a fin tool, fin brush and coil spray and there is still junk in it. we cannot remove it and clean it outside as i would love to do; its too involved to do that so we are trying to clean it in its place we have also sprayed it with a water hose and an air compressor, although it helped some i can still see gunk in it. my coils are on the bottom end of my inside unit. any advice on what else can be done to clean it well? my unit is only 7 years old. also i was told that i need to set my blower to high speed how do i do this and where is it located? thanks for any help or advice. my e-mail is map41269@yahoo.com
Oct 06, 2010 | Heating & Cooling
HEAT PUMP OPERATION FOR TEMPSTAR SMART COMFORT 2400, MODEL THC436AKC1. LOWEST OUTSIDE TEMPERATURE FOR OPERATION?
I have installed many heat pumps and if it is installed without and ouside temperature sensor I would not recommend running it below freezing 32 degrees farenheheit. Running a heat pump at low outside ambient temps. can hurt your compressor and that is the most expensive part of the outside unit.
Dec 20, 2009 | Heating & Cooling
Tempstar Air Conditioner Not Working!
Remove the top of the unit and replace the fan.
Aug 22, 2009 | Heating & Cooling
Tempstar combo unit PGAD....... 6 years old. Both blower fan and condensor fan are running but no cold air?
you have two copper lines running to outside unit larger one should be cold small one should be at body temp or slightly warm. Is the compressor running?
Jul 26, 2009 | Heating & Cooling
Possible fan motor problem. Bad capacitor or bad fan motro. Either way you ned to call a service tech. Russ
Jul 18, 2009 | Heating & Cooling
May 30, 2009 | Heating & Cooling
Tempstar air unit won't run, had electric outage but it didn't come back on with the electric. found it full of water from the condensor unit. drain pipe seemed plugged. checked fuses to the unit but it...
Your fuses can have continuity and you still may not have high voltage to run the unit. Check your circuit breaker in your main power panel. It should be marked for the A/C .
The term for the cooling coil is Evaporator. The condensing unit is the outside unit and it does not have a drain.
Jul 10, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
