Proview tv screen not centered and unclear
After 10 years with a Proview not Proscan RX326 TV, went from coax to HDMI from new Comcast digital adapter. Comcast & Proview remotes turn on TV but the screen often stays dark with no sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 06, 2016 | Proview Televison & Video
Cant find the on manual botton
front panel of TV...........center (ch... up/down.......vol up/down power)
Apr 17, 2011 | Proview PA-32JK1A 32 in. LCD Television
Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
May 22, 2009 | Proview PL916S2 Monitor
My proview monitor is not getting on i want customer care no
CUSTOMER SERVICE AND TECHNICAL SUPPORT DEPARTMENT
To contact the Proview customer service or technical support departments, please use one of the following options:
By Phone:
Service Hotline: (800) 776-8439
Office Hours: 8AM to 6PM Pacific Time
By Email:
Customer Service
Email: customersupport@proview.net
Technical Support
Email: technicalsupport@proview.net
Parts
Email: parts@proview.net
SERVICE CENTER LOCATIONS
U.S.A.
CALIFORNIA SERVICE CENTER - PROVIEW TECHNOLOGY, INC.
Add: 7373 Hunt Avenue, Garden Grove, CA 92841, U.S.A.
No walk in service at this facility, all repairs or inquires should use one of the options listed above.
TEXAS SERVICE CENTER - PROVIEW TECHNOLOGY, INC.
Add: 10849 Kinghurst, Ste. 120, Houston, TX 77099
Service Hotline: (281) 530-4100 / (281) 530-4104
Office Hours: 8AM to 6PM Central Time
--> Taiwan
PROVIEW ELECTRONICS CO., LTD.
Add: 13, Lane 195, Yung-Fong Road, Tou-Cheng City, Taipei 236, Taiwan, R.O.C.
QA Department
Contact person: Robert Tsai
E-mail: qc@tw.proview.com
China
PROVIEW TECHNOLOGY (SHENZHEN) CO., LTD.
Add: North Block 21, 23#, Shataukok Free Trade Zone, Shen Zhen China
RMA Dept.
Contact person: Dennis Chang
E-mail : ptsrma@proview.com.cn
Brazil
PROVIEW ELETRôNICA DO BRASIL LTDA
Add: Rua Acará, 203, Distrito Industrial, Manaus, AM, Brasil, CEP : 69075-030
RMA Dept.
Contact person: Cintia Andrade
E-mail: rma@proviewbr.com.br
Europe
EUROPEAN REPAIR CENTER
Add: PGL Europe Service Centre, Van Elderenlaan 28, 5581WJ, Waalre, The Netherlands
Contact person: Chris ****
E-mail: rma@pgl-service.nl
Bulgaria
LAN Service Ltd.
Add: 140 Mimi Balkanska Str. office Transpress, 1540 Sofua, Bulgaria
Tel: +359 2 960 2360
Fax: +359 2 960 2369
E-mail: office@lan-service.bg
U.K.
WARRANTY SERVICE CENTRE
GOODIES ENTERPRISES LIMITED
Add: Mile Road, Bedford, Bedfordshire, MK42 7TB, United Kingdom
E-mail: service@proview.co.uk
Service Hotline: 0870 7572944
Fax Number: 0870 7315018
Russia
PROVIEW RUSSIA LIMITED
Add: Bolshaya Novodmitrovskaya street 14, building 2, office 424, 125015 Moscow/Russia
RMA Dept.
Contact person: Ralph Leonhardt
E-mail: rleonhardt@gmx.net
U.A.E.
PROVIEW MIDDLE EAST.
Add: P.O.Box 18349 Jebel Ali Free Zone, Dubai, UAE
RMA Dept.
Contact person: Liza Manawis
E-mail: liza@proview.ae
Iran
ETIG LTD.
Add: Suite 3, #8, 16th St., Asadabadi Ave., Yousefabad, Tehran 14318, Iran
Contact person: Farshid Safinia
E-mail: f.safinia@etig.ir
Mar 20, 2009 | Proview PS 909 (White) 19 in.CRT...
Poloaroid 42' LCD tv wont come on
well if you get a screen that shows the polaroid logo with a bright ble screen then goes to black...some q's to answer for me ....does the power indicator on the lower right front of the tv go red,stays blue,or goes out completly??
Dec 13, 2008 | Televison & Video
I have proview flat screen tv pa32jk1sa and it plays sound but has no picture justa black screen what can be done
Check your cables and make sure their all in good standing.....change the "input" to "TV" and see if your get snow on the screen. If there's a snowy picture then the screen is good, if not then its a job for your local flat panel tv shop or my shop. There's definitely a problem in the video control section, or dc-to-ac inverter section.....
Nov 30, 2008 | Proview PA-32JK1A 32 in. LCD Television
I have a Proview TV that we just bought from Rent A Center and when we connect our cable to the TV it tells us to scan the channels. We did this and still we get a blank blue screen that says No Signal....
Try this as your model is basically the same as mine.
Push Menu on your remote.
Then a small screen comes up.
Using your left right arrows move left to set up.
Scroll down to tuner mode and again using left right arrows, there are 4 setting you can choose. Once the setting you choose is showing then scroll up to Channel Searching and hit OK on your remote. This will scan all the channels Digital and Analog.
Depending on which of the 4 setting you picked on TUNER MODE you may have to do this again in the next mode to see which will get the most channels on your TV.
I hope this is helpful; Ken, Attica, NY
Nov 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview 3200
Pat I do not know if you have a warranty you were required to retain the receipt from the store for the length of the warranty period to prove you have one ,also it is a good idea to register with the company on their website so they have a record of your tv and model, with your name and therefore the warranty they have included if any.LCD tv's are one of the most unsupported mass marketing consumer items that are being dumped on the US market. I think you have Blown capacitors, or more likely a problem with the power board, typically this requires soldering new capacitors onto the power board after unsoldering the blow ones and if this is all the problem is the issue will disappear, if there is an issue with a transformer, or some diode or computer chip then you might as well replace the whole power board. the capacitor issue is no big deal if you can get an electronics service center to look at the problem.
May 22, 2008 | Proview PA-32JK1A 32 in. LCD Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
