Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
Green/blue/purple vertical bars on my viewsonic va712b
There is a small green/blue/purple vertical bar on my screen that sometimes goes away but is usually there.
how do i get this to go away???
  • Josh G. Jun 18, 2009
    thks but it's not my vid. card, it even has the line when VGA is not connected
    Sergeant:
    Champion:
  • 253 Answers
You're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
When turning on the TV, it has redish, purple & green lines across the screen & you have to leave it on like that for at least 5 to 10 minutes for it to warm up. You just have to keep turning it...
Al Plasma and Lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
May 25, 2011 | JVC LT-37X688 37 in. LCD HDTV
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
Have a 56-inch Samsung flatscreen projection TV. On cable it has 5 equally spaced vertical green bars. Each green bar is comprised of 8 smaller vertical lines. It also has intermittant purple horizontal...
The digital board is bad and needs replaced. If you can get the board you hace to crack the metal chassi . Its a pain but if you are mechaniaclly inclined you might be able to do it. Pull the chassi and dissassemble. Lots of screws. Don't force anything and study it closely. It's tricky. There is also a memory transfer proceedure. The board from Samsung comes with instructions.
Mar 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Green vertical bars on a Samsung projection
That is a problem with your main board - some of your inputs work fine and another is bogus. The tv input is not working because there could be a defect in your tuner. If you have cable try a different input for the signal.from the box. If you are using OTA, then use an external HD OTA tuner to feed your set.
Sep 09, 2017 | Samsung HLR5067WX 50" Rear Projection HDTV
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Oct 12, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
577 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
