Question about ViewSonic VX2245WM LCD Monitor
Bad caps viewsonic vx2245 - ViewSonic VX2245WM LCD Monitor
Viewsonic vx2245 goes black every 30 or 40 minutes
Dear Miguel,
I think this problem came from some Capacitor of the monitor. I solved this problem with my Viewsonic VG2021M and I hope it should help you too.
Please check the link : http://www.fixya.com/support/t6862769-keep_pressing_off_button
I will follow this problem and will try to help anyway I can.
VirtualSyS
Mar 13, 2013 | ViewSonic VX2235wm LCD Monitor
Screen blanks after 3 seconds
Viewsonic uses cheap caps in their monitors, so look for bad caps with bulging top, replace them in a set.
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX2235W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 23, 2011 | ViewSonic VX2235WM Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
Viewsonic tv sound but no picture wont turn off have to unplug
For 2 years older monitor, look for bad caps with bulging tops first, post back what you see inside so we can guide you further, see example of failed VIEWSONIC with bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | ViewSonic VA1930WM LCD Monitor
VA1703wb Viewsonic Monitor backlight
The problem can be bad power supply feeding the backlight inverter circuits due to bad caps, or in the inverter circuits, or worst case will be bad lamps, you need to open it up and tell us what you see inside first, good pictures will help, see example of failed VIEWSONIC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VA1703wb Monitor
It's a Viewsonic VX715 Monitor. When it's turned ON, It goes black in 3 seconds.
It can be one of thses: bad caps (bulging top or bottom seal) in the power supply, bad backlight inverter circuits, bad lamps. You need to open it up and lool for bad caps first, then measure the voltages across the filter caps, you should have 5vdc and 12~18vdc (there are two power supplies: 5vdc for logic, 12~18vdc for backlights citcuits) Post back what you find so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VX910 19" LCD Monitor
Exactly the same problems.. It's been repaired 2 times and last night it went totally black... Bummer... but the image quality is excellent ( when it works) boooo viewsonic.. Natalie
What parts were replaced, or cheap parts were used? More likely to be either bad caps in the power supply, or bad backlight inverter circuits, see failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX2245WM LCD Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
