Question about Maytag Neptune MDG5500AW Gas Dryer
Just moved, dryer won't tumble with a load. Error code PF
Just moved and set up dryer, Attached gas line and vent added a load of clothes and machine began clicking when I pressed the start button and showed PF on display. I removed clothes and tried again with the machine empty after a few clicks dryer began to tumble and heated up like normal. Tried the load again and the machine just clicked repeatedly again and wouldn't start up. Could this be a leveling problem or a belt slipping? The tumbler appears to be rubbing inside when I attempt to turn the drum manually. How do I get a look inside the dryer to check the belt?
Thanks
Brigid
    Problem Solver:
  • 5 Answers
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Posted on Jun 20, 2009
My Whirlpool AWZ233 clothes dryer keeps stopping before the clothes are dry.
check vent line and or clean vent line inside dryer, clean vent line. Felt is probably drum seal.
Whirlpool AWZ233 Tumble Dryer Parts
Apr 20, 2018 | Whirlpool Washing Machines
Bosch classixx tumble drier lights flash
The lights are flashing as an error code? what lights are lit/flashing, what rate of flashing etc? more information may help sort this faster
Mar 24, 2014 | Dryers
Maytag quiet series 300 manual
pf is power failure because you unplugged it,is it gas or electric,that could be anything,you need to open the door,look around the opening and find the model number and send it,if it is gas you could have bad gas coils located on the gas valve,they will work for the first 15 to 20 minutes and when they heat up they will fail only if they're going bad so the clothes will feel warm but not dry,also you still could have a block in the vent line or in the duct where the lint filter slides into,there's a blower wheel in there that blows the air around,remember all a dryer does is move hot air around to dry the clothes,the easiest way to check the line is to remove it from the back and run it,but first clean out where the lint filter slides into
Oct 01, 2017 | Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
CLOTHES DRYER (ELECTRIC) HAS HEAT AND TUMBLES BUT CLOTHES ARE NOT GETTING DRY.
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER. RUN ONE LOAD OF LAUNDRY. IF THE LOAD DRIES O.K., THE EXHAUST DUCT IS RESTRICTED. CLEAN OUT THE DUCT WORK. IF IT IS FLEXIBLE MATERIAL, REPLACE WITH RIGID METAL DUCT WORK.
Apr 22, 2008 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
142 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
