Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Can i do it my self
Can i replace the ic chip in my 56 inch jvc big screen myself
  • 6,784 Answers
HI. we highly recommend a service tech for this issue. there are many things that can go wrong here if the IC isn't soldered correctly. if you are not an experienced tech, we recommend calling for service.
Posted on Jun 18, 2009
What is needed to converge a 65 inch JVC and an approximate cost?
U have all the tools,also u can do basic soldering work like take out ICS and putting back in ICS chips on a electronic circuit board and take out small electronic components parts and replaces all those small dead components parts resoldering it back on to a circuit board?Yes?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a whole complete convergence kit will also included a DVD tutoring disc belonging to ur DLP tv make and model u are buying will cost u like $70.U do the labors to fix it ur self.Or the tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Jvc AV-48WP30 iart pro the color on the screen is falling down on the left side the colors are not overlapping so it doubles what ever im watching
Replace your STK iCs, they are big black ICs will have the Part number on them example STK392-110
Mats has STKs 1-800-628-1118
Jul 02, 2010 | JVC AV-56P575 56" Rear Projection...
My 57 inch jvc screen will shut off and then the blue light will keep blinking not allowing me to turn it on or off or anything until i unplug it. then its ok for a while? why does it do this?
Convegence ICS is the cause.It dying,replaced the convergence ICS well solved this problems.U know how to solders?Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 04, 2010 | JVC AV-56P575 56" Rear Projection...
Picture is in 3d and green red blue
replace Both of your convergence ICs They are big black chips will have STK# on them also in same circuit there will be two low ohm resistors that might be bad 2.7 ohms CK them .
Jun 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
I art JVC 46 inche double vision
If you do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
Good Luck.
May 24, 2008 | JVC AV-56WP74 56" Rear Projection...
Converge problem how to fix JVC AV56wp74
There are two of the IC's in the tv. First things first, turn the tv off and unplug it. Wait a few minutes, then open up the back by unscrewing the screws in the back panel. Now slide out the wooden panel that divides the upper and lower part of the cabinet. You'll see some cards sticking out of the plastic input panel. Find the one for DVI (it's the furthest to the right and it's at the top). Unplug all of the cables that are attached to this board. If you look closely, on the top of this board (the edge facing the top of the tv) there is a tiny little square looking hole on it. Cover this with black electrical tape or something that will not allow light in. The reason we do this is because JVC made a booby trap that erases the eeprom if you try and operate the tv with the back off. If the sensor senses light when the tv is on, it will erase the eeprom. Ok well now that that's covered, the actual convergence board (the one with the two IC's) is the board in the very front of the tv. It's long and slim and you'll immediately be able to see the two IC chips. They are big black things with lots of pins and they are pushed up against heatsinks. Those are what you would want to replace. Now I've not taken the boards out before, but from the looks of things, all of the boards are on a big black plastic tray so you can take them all out at once. I don't know if you can get just the convergence board out very easily, but at least now you know where and what it is. I would seek further instruction from someone a bit more knowledgeable about taking the boards out, but that should give you enough to do until you find more help. Hope this helped!
Jul 31, 2007 | JVC AV-56WP74 56" Rear Projection...
Tv screen waves and is double
No. You have bad convergence output ic;s and probably at least 1 burnt resistor. This liely will have to be reconvergec in the servcie menu after the aprts are changed.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 12, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
141 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
