Question about Bosch Kitchen Ranges
Bosch range error 120 on bosch range - Bosch Kitchen Ranges
2 Suggested Answers
SOURCE: while runing the clean cycle
I PURCHACED A BOSCH HGS7282UC GAS RANGE 6 MOS AGO. THE DOOR WONT CLOSE TIGHTLY,THE HEAT ESCAPES AND HAS MENTED MY KNOBS ON THE STOVE
Posted on Sep 26, 2008
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My gas convection range bakes just fine but fan is not working any ideas?
Chances it is a fan failure. Check the wired to the fan as well. If able, place 120 volts to the fan wires to see if the fan starts. If the fan works then it is not the fan. but the fan and the surrounding wires would be my first suspects.
Oct 23, 2013 | Bosch HGS 255 Gas Kitchen Range
Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Apr 30, 2010 | Kitchen Ranges
Bosch convection oven in self clean mode, am getting an error code of 41
Hi, I am getting the same error today. Did it ever clear up? Were you able to open the door eventually?
Jan 24, 2010 | Bosch Evolution Pro-Style 700 HDS7282U...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
While runing the clean cycle on my 2 day old bosch hgs7282uc gas range, it came up beeping error code 120 after an hour or so of it running.
Apr 29, 2008 | Bosch Kitchen Ranges
Error message
i couldnt find it either sorry but dont worry about it unless it returns
Dec 10, 2007 | Bosch HES 232 / HES 236 Electric Kitchen...
Kitchen Ranges Logo
50 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
