Question about Frigidaire Washing Machines
Frigidaire fwl22sa decharger water pump
2 Suggested Answers
aghashie
SOURCE: i have a frigidaire model fwl22sa it startted
Same problem here with same make/model. I am not an expert "washing-machine-guru", but I do have a fair level of technical knowledge. Well, when I inspected my washer looking for the problem I found that the rubber hose used to move water from the drum to the extraction water pump is broken. The water escaping the hose is spilling over the electric motor, motor belt, drum brake and water extraction pump. I removed the hose and inspected it looking for the reason it broke. All I can say is that I think that the material (rubber) used is not top quality. Apparently the cause of the failure is age. Maybe the chemicals running thru it may have debilitate the hose to the point of failure. The drum brake is not operating normal, retaining the drum from spinning when it should be. Also the motor belt have stretched a little bit, maybe because of the water spill. If your Frigidaire FWL22SA is leaking water when the drum is being filled you better refrain from using and inspect the hose. I buy the hose (original spare/repair part) for only $3.99 and installed myself. That is far cheaper vs buying a new washer. Good luck.
Posted on Jan 18, 2012
I have a Frigidaire dishwasher model number FGBD2431KF purchased around 2009. Water is not pumping out.
Sc. Check the drain valve, remove the pump and test it. If it is not the pump then probably a relay or switch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dishwasher Diagnostic Repair Not draining Frigidaire Electrolux...
Dishwasher Not Draining Dishwasher Drain Pump Replacement Part 5304463777
Frigidaire Dishwasher Not Draining
http://www.partselect.com/Repair/Dishwasher/Not-Draining
May 08, 2016 | Frigidaire Washing Machines
I have frigidaire FWT449GFSI,the water can cont come out
HI, check the following to address this issue.
1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire model fwl22sa it startted leaking and now it stopped spinning
Aug 18, 2009 | Frigidaire Washing Machines
Water isn't being pumped out. Does have power.
I assume you are referring to a drainage issue within the unit. check the following below.
2. Water Pump
May 30, 2009 | Frigidaire Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
How to check the water pump on a Frigidaire FTF530ES
you can take the belt off and turn it by hand to see if it is hanging up and moves freely,take hose off to check impeller inside,most of the time if its lound during spin it's the transmission,if it is a humming sound the water pump-mike
Nov 03, 2008 | Frigidaire FTF530ES
Ponding of water after washing
hi there,
check the drain pump for any blockage. from the sounds of it, the pump does not dispose of the water completely. if there is nothing visible, replace the drain pump.
Mar 23, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Washing Machines Logo
11 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
