Question about ASUS Eee PC 900 Notebook
Asus PC 900 HD wifi connection failed?
Just bought laptop and ran wizard everything downloaded ok, but wont connect to internet. Bought a router although my DSL should already act as one, I have bellsouth dsl, it tried to connect to google but failed again. I thought this would be easy, am I doing something wrong? All the correct lights are on says working good, but still says I am working offline
  • 4 Answers
Click f2. if that doesnt work then
go to start and go to control panel,
then click on internet options, click on the advanced tab, and click reset, there you will find connectivity or internet or something, click on the cross which brings more info up, it should bring up atheos ethernet, and atheos wireless, delete/uninstall them both. then try to connect again.. should work.
Posted on Jun 26, 2010
    Sergeant:
  • 338 Answers
Check if the build in wifi finds your router/the home-WAN u already use(??)
turn over router, write down the WPA-nr (16 digits)
use logon program-tool provided with router or laptop,
if working, it should at least display some of the wifi-nets/hot-spots/WANs available at ur place,
then log onto your one, enter wpa-key(is password and for encrypting your connection)
choose defining ip-config using DHCP-standard/automatic ip-adressing,
a network-connection symbol may now pop up at lower right on the task bar :
and retry surfing.
good luck
Posted on Jun 18, 2009
Lenovo Laptop won't connect to internet?
Might be your wifi adapter has failed try installing external wifi us \b card
Dec 02, 2015 | Lenovo Computers & Internet
I am trying to connect my computer to the internet via cable. Other laptops are working ok, asus PC 900 is not able to connect. In a bottom right corner is sign that network cable is unplugged, in the next...
Try to plug the network cable into another port on the router and then try again. If you still cannot connect and get the connect/disconnect again...your network card may be bad.
I would download a new network card driver from the asus website and see if that makes a difference before actually replacing the network card. You can always buy an external USB network to save money but it will be bulky.
Jun 01, 2010 | ASUS Eee PC 900 PC Notebook
I have just bought a laptop running Windows CE 6.0. It connects to the Internet through WiFi ok, ( i tried it at McDonalds ) but when I try to connect using my broadband Internet connection I have at home...
You MUST disable the Wifi for it to use the Ethernet OK. Then maybe even be best to run the connect to internet wizard. and tell it which adapter to use... As one generally never uses both at same time, it is best to enable and disable as required.
Jan 31, 2010 | Computers & Internet
I cannot connect to the internet on my Acer EeePC 900. When I select my network it says limited or no connection. I tried uninstalling and reinstalling but it still wont work. I have windows XP. Its...
If you are connecting via wireless, the reason is usually because your router has lost its internet connection. Try switching the wireless router off, waiting 10 seconds and switching it on again. Can you explain how you are trying to connect and if you can use any other computer successfully, etc.
Jan 02, 2010 | ASUS Eee PC 900 Notebook
Problem with internet connection
Try to uninstall the wifi drivers , and to re-install them
Nov 18, 2009 | ASUS Eee PC 900 Notebook
ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Jan 24, 2009 | ASUS Eee PC 900 Notebook
I have receintly bought a dlink wireless notebook adapter so i could set up my wireless wifi network at home to connect my compaq presario 900 to from a PC. I have installed everything and im getting a...
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks?
I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS.
Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again.
Hope this helps.
Jun 21, 2008 | Computers & Internet
ASUS Eee PC 900 Notebook Logo
475 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
