Question about Saws
Ridgid 4007 tile saw manual
Need manual
  • 8404 Answers
SOURCE: Ridgid Wet Tile saw water pump operates, however
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Posted on Oct 21, 2009
SOURCE: ridgid tile saw wts
I cut mine off!! then put a normal plug on it. Works great.
Posted on Oct 23, 2010
  • 29 Answers
SOURCE: I purchased the new Ridgid tile saw named " The
sounds like your blade is to high,your diamond blade should be about 1\4 to 3\8 of an inch below the slide tray that your tile sits on,also make sure you dont have the blade on backwards,blade will wonder off when cutting a blades width off edge of tile,try standing up front of tile when into cut leaving bottom of tile securly down
Posted on Jan 06, 2011
  • 354 Answers
SOURCE: need to buy a switch
You need the guts of the switch not the entire switch and he guts csan be foud at the shack or an appliance store
Posted on Feb 16, 2011
  • 157 Answers
SOURCE: need manual for 7-inch wet
Hello. Found the manual for you at:
http://www.northlandconstruction.com/products/4125/techsheet/QEP%2060087%207in.%20Wet%20Tile%20Saw%20Brochure.pdf
If this helped, please rate a four thumbs on this answer.
Thank You.
Posted on Mar 23, 2011
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
I need the on an off switch for the Ridgid WTS2000L tile saw
Try www.ereplacementparts.com if they don't have it you can special order it through the customer support of Home Depot.
Aug 15, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
PLEASE - I cannot locate where to buy parts for a Ridgid saw (WTS200L)
The Ridigid WTS2000L Tile saw is actually built by Chervron North America and not directly supported by Ridgid. You can reach them at 866-974-3443. This is a direct line for WTS2000L service.
Hope this helps. Positive feedback always welcome :)
Mar 03, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
The arm that holds the motor to the tray, broke and cant find any replacement part, why is that?
Go to the Rigid web site and get their coustmer number they have replacement parts there.http://www.ridgid.com/ Shows you saw and parts for it.
Nov 11, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Nada
According to my translation your question is:
"I would like to know the price of water for cutting ceramic tiles"
Your best bet is to figure out how much water you will require and then call the water company to inquire what the charges would be for that amount.
Aug 17, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Saws Logo
32 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
