Question about Dometic Rooftop RV Air Conditioner
My low speed works but high speed don't work on my air conditoner rv dometic air
    Genius:
  • Dometic Master
  • 1,363 Answers
Relay module, communication cable to relay module from t-stat.
Posted on Aug 17, 2015
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
22yooper
  • 828 Answers
SOURCE: PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Posted on Jul 24, 2008
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
SOURCE: Air conditioner short cycling
my Carrier package unit is goining off on short cycles. What should I trouble shoot first?
Posted on May 14, 2011
ZJLimited
  • 17970 Answers
SOURCE: need to install a dometic
A schematic of the part number can be found here... Duo Thermostat Wiring.pdf
Additionally, go HERE for the Dometic Service Manual. See pages 39 and 40 as well as 50 and 51. Depending on which unit you have this gives the colors coding for the leads as well as the placement on the thermostat.
Hope this helps; keep us updated.
Posted on Jul 07, 2011
Why does my Duro-Therm by dometic roof top air conditioner make extra chatter noise on high speed but not on low speed?
clen fan blades at both end of motor. the temperture will be colder at lower fan speed. depending on age and useage the bearings might be going out in motor.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
No heat from heat pump
if outside temperture is to low it will lock out heat pump operation.
Nov 07, 2013 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Freezes up in less than an hour used 3 times and freezes each time model 59516 serial#93421578 installed 12-4-2009 dometic roof ac
You are either low on refrigerant, dirty coil or filter or your blower is not working or running at the proper speed. Make sure you have the blower on high speed, then, if it freezes up you are probably low on refrigerant. You need to have a HVAC service technician check it out, unless you are fimiliar with or work on air conditioning systems.
Jun 09, 2010 | Dometic Rooftop RV Air Conditioner
My rv air wont work on high?
could be the selector switch turn off power switch low and high wire if it blows high replace selector switch if it does not work replace motor. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
Nov 24, 2008 | Dometic Rooftop RV Air Conditioner
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
44 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
