Question about KitchenAid Architect KUDS03CT 24 in Builtin Dishwasher
Kitchenaid KUDS03ct top rack doesn't clean - KitchenAid Architect KUDS03CT 24 in Builtin Dishwasher
techcrazy
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
  • 37 Answers
SOURCE: Upper rack dishes not cleaning well
Yes, run an empty load with 1/4 cup vinegar. It sounds like there is mineral build up in the arm. Try to take the arm apart that supplies water to the top rack of the dishwasher. You can soak this in vinegar water once removed.
Posted on Mar 16, 2009
localwonder
  • 6784 Answers
SOURCE: My kitchenaid dishwasher is not cleaning the
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Posted on Jul 08, 2009
  • 26 Answers
SOURCE: Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Posted on Sep 27, 2009
  • 715 Answers
SOURCE: the dishes on the top rack are not coming clean
check top spray arm to make sure all of the spray hole are clear
Posted on Oct 09, 2009
Top rack not getting clean on Normal Cycle
Empty the dishwasher. Look at the 2 rotating plastic arms in it (like 2 bladed windmills) spin each one, do they move freely without hitting anything? If so remove the top one (its a press on fit) the look inside it with a torch, is there any debris or dirt inside it blocking it? Water has to flow inside it or it will not spin, and top rack gets no water spray.
Dec 20, 2013 | Dishwashers
Dishes in top rack do not wash
spray arm is probably clogged due to hard water. go to www.dishwasherfilter.com and get the dishwasher filtration system.
Oct 21, 2011 | KitchenAid Architect KUDS03CT 24 in...
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
The dishes on the top rack are not coming clean
Oct 09, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Jan 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Delamination
its not supposed to as there is not that much steam coming out if it does contact whirlpool and check your installation instructions
Mar 28, 2008 | Dishwashers
KitchenAid Architect KUDS03CT 24 in Builtin Dishwasher Logo
16 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
