Question about VeriFone VX510
Need to reboot - VeriFone VX510
  • Kelli Sims Mar 16, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Who do you reboot?
I couldn't read the information on the screen.
If you need to reboot, there sometimes a reboot button. Pressing and releasing it will cause the computer to reboot.
If there isn't a reboot button, press and hold the power button until the computer turns off. Release the button and press and release it to reboot the computer.
Good luck.
Paul
Feb 17, 2016 | Computers & Internet
Tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 | Cell Phones
Reboot need on Toshiba Satelitte
Rebooting from the Windows OS can be done y a variety of means, depending upon the version of the OS. Clicking the START button or pressing the Windows key on the keyboard will get you to the POWER option where you can select RESTART (which is a reboot).
If you are not in Windows at the time, you can usually press the CRTL-ALT-DEL combo and get a reboot. Lastly, press and hold the POWER button until the device fully shuts off. Wait a few seconds and then power back on to get a reboot.
Dec 15, 2015 | Toshiba Computers & Internet
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
My Z92m laptop keeps rebooting how can i fix this
You need to turn off reboot on error. Hit F8 several times a second on reboot before the OS windows appears. Scoll down and turn off reboot on error.
Now you will see what the error code is.
Oct 04, 2011 | ASUS Computers & Internet
I HAVE AN ACER LAPTOP AN ITS SAYING I NEED TO REBOOT IT BUT I DONT HAVE A REBOOT CD WHAT SHOULD I DO PLEASE HELP
Hi,to reboot you just need to restart the computer.Thats it your done,don't for get to rate.....
Oct 27, 2010 | Computers & Internet
Need to reboot samsung p35 laptop but i don't have any reboot discs. I took it once to a computer tech place to get it rebooted but a lot of the keboard functions were lost and it very quickly became...
reboot is simply mean restart ur pc and load the software and necessary file during booting. If any system file is lost then u will need system boot disc for either repair or format ur sytem.
Jul 28, 2009 | Computers & Internet
Need 2 reboot
If you don't mean retore and just reboot. just click restart when you shut dow
Jan 04, 2009 | Computers & Internet
Reboot to get rid of virus
When it says to "Reboot" it means to restart the machine, shut it down and then turn it back on again.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Reboot
u don't need to reboot, if the ups is doing it it may have a board problem
Jun 21, 2008 | Powerware 9120 UPS System
VeriFone VX510 Logo
52 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
