Question about Pride Jazzy 614 Hd JAZZY 614HD
Where are fuses on jazzy 614 hd wheel chair
Control lights on arm rest come on afew seconds then go off.
mohammed387
  • 1952 Answers
SOURCE: jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Posted on Mar 27, 2009
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 50 Answers
SOURCE: Our Jazzy Select G.T. power
Hi
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
Posted on May 05, 2011
Why won't the jazzy chair turn back on. I only get running lights on the controller
Is the controller locked? Does the controller beep? The best way to troubleshoot the problem is to go up on Jazzy's website and download the service manual
Oct 07, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Center drive wheels doesn't get traction
I have been using power chairs for over 15 years. I have used or driven many brands/setups. If you're Invacare chair has six wheels that contact the ground all the time, this set up is horrible for anything other than a perfectly flat surface. My old power chair has six wheels, but the two front wheels only touched the ground on uneven surfaces or if the chair pitched forward. In Invacare's defense, their setup provides a smooth ride without pitching forward during fast deceleration. But, the "spring arm" tension on the front wheels is so strong that on uneven surfaces, they tend to lift the chair enough that you can lose traction, especially outdoors in the yard, etc. It is rather difficult to do, especially if you are unable to get down on the ground, but I have jammed small wooden spacers into the gap that opens up when the spring arm is lifted. It is difficult to see and difficult to insert the spacers, but the improvement is drastic. I used a small rectangular block of wood per side, almost 1/4 inch thick, and it raised the front wheels off the ground by about half to 3/4 inch. I used double-sided sticky foam strips to hold the blocks in place, but over time they eventually fall out. Maybe next time I will glue them in place. Hope this helps!
Feb 24, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD goes into lockout. We can get it out of lockout but goes back into lockout at any movement of the chair........
Make sure any seating system is completely down and in DRIVE position. When chair is unlocked, wait 5 seconds, shut chair off, wait 5 seconds, turn chair back on. Each time you turn the chair on you need to wait 5 seconds for the POST to complete before moving the joystick.
Oct 14, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My jazzy power chair will not pull an encline ,batteries are new and fullu charged
do you exceed the weight limit? not trying to be rude but they do have limits, if not please elaberate on the fault, more detail how the chair responds if it cuts out if lights flash or beeps, etc.
Sep 15, 2013 | Pride Mobility Pride Jazzy 614 HD
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Chair beeps when off
The PGDT controller may have been programmed to go into sleep mode. If so, if the chair isn't used for up to 10 minutes, the chair will go into sleep mode - then beep every once in a while to remind you it is sleeping.
Go ahead and wake it up and then shut it off. It won't mind.
Oct 05, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Pride Jazzy 614 Hd JAZZY 614HD Logo
110 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
