Question about Vehicle Parts & Accessories
Timing belt chrysler sebring lxi
Died chugged never started but would try to turn over
    Novelist:
    Champion:
  • 239 Answers
What year? what engine? 4 cyl/ 6 cyl? need more info. I've changed a number of them.
Posted on Dec 03, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Ecm ecu computer is out on 99' chrysler sebring lxi
I have the same problem with my 99 sebring lxi, I'm getting a new ecu for the transmission and the engine, hopefully that fixes it. Did the car randomly die and wouldn't start again or when driving keep the transmission in one gear and wouldn't change?
Jan 17, 2012 | 1998 Chrysler Sebring
Where is the timeing belt on a 1999 2.5 v6 lxi chrysler sebring at?
The timing belt is locate at the front of the engine, underneath a cover. Here is a picture of it with the routing and timing marks
May 10, 2011 | 1999 Chrysler Sebring
I have changed the timing belt on my 2002 Chrysler Sebring LXI coupe and the car runs great when it stays running. When I shut the car off and start it back up it just starts and dies but if i unhook the...
Check the throttle plates and idle speed control motor make sure there both clean.
Also check manifold vacuum at idle the best you can hold an idle. I have run into timing belt being one tooth off and engine still ran fine. But the vacuum was low that's how I could tell the belt was a tooth off.
Oct 27, 2010 | 2001 Chrysler Sebring
I have a 1998 Chrysler Sebring Coupe Lxi and have
first as a rule of thumb, check your fuses
then check for spark at the spark plugs
then check for fuel at the fuel rail
you should eliminate some of the system at this time
Mar 08, 2010 | 1998 Chrysler Sebring
How often do i replace the timing chain 1999 chrysler sebring lxi
The belt is supposed to last for 105,000 miles. These sebring cars are notorious for breaking timing belts well before then. If your car has over 80,000 on it I would schedule a timing belt change in the near future. Don't be surprized if you have to also change the water pump.
Kelly
Feb 27, 2010 | 1999 Chrysler Sebring
1997 Chrysler Sebring LXI V6 Coup Belts - inside or outside?
There should be a sticker under the hood that shows the belt routing. If not go to a parts store, Autozone ect and they can look it up and print it out for you
Jan 09, 2010 | Chrysler Sebring Cars & Trucks
Will not start, 1999 sebring LXi coupe
check your timing belt and make sure the timing is on right
Jul 14, 2009 | 1999 Chrysler Sebring
2001 Chrysler Sebring battary dies alternator is new
check the glove box and trunk..most time the are the route to all evil..lol.. you can see the lights because the box is closed and trunk is as well.. i hope this helps you..keith...
Mar 14, 2009 | 2001 Chrysler Sebring
2002 chrysler sebring lxi 2.7l sedan
well to make sure it is the laternator start the car and pull the positive battery cable. if the car dies it is the alternator. and usually even on the new cars. it is easy to get to. just look at the front of the hood for the belt diagram and it will tell you how to release the belt.
Jul 18, 2008 | 2002 Chrysler Sebring
Vehicle Parts & Accessories Logo
57 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
