Question about Whirlpool Refrigerators
WRF560SFYM00 I want to clean it. How do I turn it off so I can?
I don't have a clean button on my Crosley oven need cleaning very bad.
turn it up to maximum heat for 30 minutes, turn off and leave to cool. Self clean will only clean the coated sides of the oven.
Sep 20, 2015 | Crosley Kitchen Ranges
Sd0452a stuck in clean mode
When a Manitowoc is turned on in clean mode, It stays in clean mode until it finishes (about 30 minutes).If you turn it off and then on again,it just keeps cleaning. Let it run in cleaning mode until it finishes then turn the witch to ice mode.
Mar 25, 2014 | Manitowoc Kitchen Appliances - Others
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
I have no instructions for my roomba 560 so dont know how to start it
Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
I accidently turned the oven to clean and the lock came out and I turned off the cleaning feature but I can't get the lock to go back in. So now the door won't shut all the way.
Open the door find the door switch hold it in while turning the oven into clean allow it to start the clean cycle then cancel the clean cycle and don't release the door switch until the latch stops
Feb 15, 2010 | Ovens
I lost my manual on how to use the self cleaning on my cuisinart coffee machine
Decalcification
Decalcification refers to the removal of calcium
deposits which form over time on the metal
parts of the coffeemaker.
For best performance from your Brew Central
Thermal™ Coffeemaker, decalcify the base unit
from time to time. The frequency depends upon
the hardness of your tap water and how often
you use the coffeemaker. The flashing Clean
light will indicate when you should clean your
coffeemaker.
If the Clean light begins to flash when the
coffeemaker is turned on, it is telling you that
the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir to
capacity with a mixture of ¹⁄³ white vinegar and
²⁄³ water. Press the Clean button. When the self
clean light glows, turn the coffeemaker on by
pressing the on/off button. The Clean light will
shine steadily. The coffeemaker is now in Clean
mode. One cycle should be sufficient to
adequately clean the coffeemaker. When the
cycle is completed and the five beeps sound,
the coffeemaker will shut off. Turn the
coffeemaker ON to see if the Clean light
continues to flash. If it does, turn it to OFF and
then repeat the cleaning procedure with a fresh
solution of vinegar and water.
If the Clean light no longer flashes, turn the
coffeemaker to OFF and then run one cycle of
fresh cold water through the unit before using
the unit again to brew coffee.
Notes on the Clean F unction
Pressing the Clean button cancels all other
settings. If it is pressed accidentally, press it
again to return the coffeemaker to all its
previous settings. Pressing ON/OFF will also exit
the Clean Mode and turn the coffeemaker OFF.
Directly from the DCC-2400STR manual
Feb 14, 2010 | Cuisinart Coffee Makers & Espresso...
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
