Question about Powerhorse Gas-Powered Pressure Washer - 2.5 GPM, 3000 PSI, 208cc
Wan't start will not start
GETTING A MESSARE...WAN MINIPORT 2 AND 3 CANNOT START
Go to device manager and delete those and then power the unit off and on and see if they are redetected.
Apr 08, 2014 | Dell Studio 1555 Laptop Computer 15.6-Inch...
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How to gt wireless printing working?
when you start the installation, it will prompts for waht type of connection you want , LAN or WAN, choose WAN or wireless.
More at HP Support & Drivers .
Oct 19, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I have exclamation marks on wan miniport sspt and wan miniport (network monitor)#2,i am having problems with my desk top (vista)how do i solve these problems
An exclamation mark means the driver is not installed correctly or the hardware is not being started right. In device manager, try right clicking the device and clicking uninstall, then click scan computer in the upper toolbar of the window to reinstall the WAN Miniport
Dec 30, 2009 | Evesham Computers & Internet
Engine will not start when the water is on. You can start the engine and then turn the water on but it will kill the engine. I have tried to clean the unloader valve.
To isolate whether or not the unloader valve is still stuck or sticking, try starting the unit with the wan trigger engaged water coming out to spray. If the unit runs while wan trigger is engaged and shut down when released your unloader valve isn't working. Hope this helps God Bless
Sep 18, 2009 | Garden
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
Dynamo R-ADSL-C4W-EG WAN light
Have you conifgured it with the proper credentials? PPPoE or PPPoA? (since using a filter normally indicates a DSL connection)
Dec 22, 2007 | Computers & Internet
Powerhorse Gas-Powered Pressure Washer - 2.5 GPM, 3000 PSI, 208cc Logo
67 people viewed this question
Top Powerhorse Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Powerhorse Garden Expert? Answer questions, earn points and help others
