Question about Fiesta Blue Ember Gas Grill
Can't get grill over 300 degrees - Fiesta Blue Ember Gas Grill
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
Cannot get temperature over 300 degrees anymore
It was the regulator bypass.
For details see:
http://weber.com/support/faq/faq.aspx?id=1
Jul 18, 2009 | Weber Genesis Silver B Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
May 19, 2009 | Weber Genesis Silver B Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
I can't find anything in the instructions on the length of time it would take to cook a turkey. Only the temp. of he meat
This may be too late, but you can generally figure on about 20 minutes per pound at a grill temperature of around 300 degrees. This is where a good instant read meat thermometer is your best friend. Take the temp in the deepest part of the breast and in the deepest part of the thigh starting at about the 15 minutes per pound mark and then about every 15 minutes after that.
The reason you see so many comments on the temp of the bird rather than the cooking time is that some folks cook their birds at 200 - 225 degrees, and others at 275 - 300 degrees or even up to 325.
I cooked a 5.5 lb turkey breast yesterday and it was ready in about 90 minutes at about 300 degrees.
Good luck and good grilling!
Pat
Nov 27, 2008 | Grilling
Fiesta Blue Ember Gas Grill Logo
66 people viewed this question
Top Fiesta Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
