Question about HP Compaq Evo Notebook N600c
Compaq Evo N600c won't boot up
When I hit the power button to boot up the laptop the leds come on for a few seconds & then go off . The laptop then starts cycling thru this, leds on for a few seconds & then off & just keeps cycling & nothing else happens
  • deekay1 Jun 18, 2009
    I have reseated the memory & tried booting without the hard drive & cd drive, same problem.
  • 3 Answers
Check voltage of AC adapter with voltmeter and make sure voltage matchs the output noted on the adapter and the bottom of the laptop.
Make sure the voltage is steady and not jumping all over. If you have another adapter with the same output voltage and AMPs equal to or greater than the required AMPs, try that. This will rule out the adapter if you still have the same problem.
Posted on Jun 18, 2009
    President:
  • 2,653 Answers
Reseat / swap the memory.
Try booting without the battery and if possible the hard drive and dvd drive.
More than likely the motherboard is toast but if you do what I said, we'll know for sure.
  • RescueTechLA
    RescueTechLA Jun 18, 2009
    Motherboard problem for sure. It's really common with that model.
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
On start up of my compaq evo n600c the screen
Have check by a technician because the ribbon cable that runs behing the screen is loose.
Jul 16, 2009 | Computers & Internet
N600c laptop manuals
Go on this site and download it...
http://pdftown.com/Compaq-Evo-n600c-Service-Manual.html
Jun 23, 2009 | Compaq EVO 600C Notebook
How to boot from cdrom
I believe you hit F10 key to enter bios. Go to the advanced menu and select boot options. You can select in there what order the computer tries to boot from different options. You need to select boot from CD and put it in sequence before the hard drive. Most bios versions well give you a first, second, third boot device and so on. Set first device to CD rom, second to Hard drive 0, third to none unless you use a floppy drive to boot from (rare).
Jun 01, 2009 | HP Compaq Evo n600c Notebook
Compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Mar 26, 2009 | HP Compaq Evo Notebook N600c
All white screen on compaq n600c
When you hooked up external monitor, did you switch to it via "Fn" keys?
If it did not help, then it's GPU ot North Bridge on the board that needs service.
Mar 19, 2009 | HP Compaq Evo n600c Notebook
Need help with Evo N600c battery Pack
Wouldnt fancy taking one apart myself, replacement ones are not very expensive, look here on battery trader , Compaq Evo N600c laptop battery
Dec 08, 2008 | HP Compaq Evo Notebook N1000c
Reboot
You can insert the OS installation CD and hit F11 or F12 to get to the boot menu. The you can wipe out your hard drive and put a fresh copy of windows on it.
Apr 18, 2008 | Compaq Evo N600c Notebook
Evo N410c- Won't boot
can you go to the bios info? if yes check the time if that is rong change the inetrnal batery and loock for the hd and the boot order set to 1st hd than save that and see what does now if you can not go to bios so you have to check the batery and the ac adapter
Dec 26, 2007 | Compaq Evo N410C Notebook
HP Compaq Evo Notebook N600c Logo
297 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
