Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Speed pot fault - Pride Go-Go Ultra X 3-Wheel Travel Scooter
Flashing code 1, 3 speed pot fault
Usually turning the key off and removing it then re inserting the key and turning it back on without touching the paddle levers. If that doesn't fix it then the speed pot will need to be replaced.
Mar 16, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Speed pot fault
Try using a contact cleaner in a spray form. Like a can of CRC Contact cleaner or Deoxit contact cleaners. Potentiometer [Pot] are not sealed so find a hole and spray into it. Use a liberal amount of cleaner. Work the pot while spraying.
You can test the pot by using a analog multimeter You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Using the multimeter.gently turn the pot up and down the multimeter should read zero when the pot is turned fully clockwise. Now turn the pot fully counterclockwise. As you tern the pot the meter should smoothly rise to 30k ohms, The meter needle should not bounce or drop off, it should move smoothly at all times. If the meter bounces clean the pot again you will likely see improvement. I've had to clean pots a number of times before the pot is clean. Hope this helps.
Sep 14, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
Status light beeping once then twice everything works but not driving was going allright befor and fully charged
Hi. This fault code is normally associated with a faulty speed lever. Could be a faulty pot, broken wire on the pot, or a plug fallen off the circuit board.
This fault code is normally displayed by a Curtis controller, if your machine has a different controller, it might mean a different fault has occured.
Good luck. Neil.
Jun 08, 2010 | Pride Mobility Products Go Go Ultra X 3...
Scooter shows "speed pot error". How do I fix that?
You will more than likely need a new speed pot but some are connected to the throttle pot as well so it could be that which is at fault. Could also be wiring or worst case, control box but this is unlikely.
Feb 20, 2010 | Pride Value Line Revo Scooter 3 Wheel
SCOOTER WON,T MOVE OR MOVES ERRATIC LED INDACATES SPEED POT AT FAULT
hi, ok that's sounds about right, the speed pot hat is attached to the throttle lever is normally about 5K in value.
Feb 14, 2010 | Hurricane Pride PMV Mobility Scooter -...
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
It appears to be out of power but suddenly the power reappears I
ok, that could be one of three things,
A bad connection with the battery so lift the battery and check contacts,
Check wiring to the speed pot, you will have to remove the top unit that house the speed pot etc (Wign wam)
A faultly speed pot is the other cause, to confirm trying moving the pot up and down, is there a lot of play , try moving the lever slowly, if it jerks about, it needs replacing.
Regards
GeWiz.
Oct 17, 2009 | Shoprider Scootie 4 Wheel Scooter
Pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Apr 24, 2009 | Drive Medical Mini Phantom Three Wheel...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
