Question about General Electric Monogram® ZGU385NSMSS (Gas) Stainless Steel Cooktop
Modual igniter for GE # ZGU385N
What is the price of this part?
GAS DOES NOT IGNITE ON COOKTOP
if non of them are sparking, and it use to work, most likely, you need a new spark modual,
Oct 17, 2012 | GE 30 in. JGP328 Gas Cooktop
All lights and ignitors on my GE ZGU385N (Gas cooktop) stopped working all of a sudden. I checked the input voltage to the transformer and all looks fine so I know the issue is not with the outlet or power...
Disconnect power and set you meter to ohms. Check the both the line side and the low side of the the ****** for continuity. If you cannot get a reading from either side then that puppy is bad. More than likely that is gonna be it since everything quit. If it was the igniter box you might have weak spark etc. I thnk that transformer is your prob.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 11, 2011 | General Electric Monogram® ZGU385NSMSS...
The igniter on my GE cooktop wont stop clicking, only if i unplug it.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
Aug 27, 2011 | GE Profile JGP636 Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
ALL THE BURNERS ARE IGNITING WITH THE KNOBS IN THE OFF POSITION.
Most common is either your spark modual is bad or one of your ignitor switches is shorted.
More information will be needed to help you further
Model # off the machine. are you refering to the clicking noise and how often is it. just constant or once ever 10 min ?
if its constant then i would start with the Switch if has time between them 3, 5, 10, 15, 30 min I would go with the Spark modual
Jan 10, 2010 | Cooktops
The electric ignition sparks even when in the off position
did you spill any liquid in/on the cooktop? sometimes it just takes time to dry out. or you need a new spark modual
Apr 19, 2009 | GE Cooktops
One of 4 burners doesn't spark/light -- GE JGP979 Cook Top
I am going to assume you hear the "clicking" sound when you try to light the burner.
open the top of the stove. there are four burner. look at the one that is not lighting. use a straighten paper clip open the holes that is directly in-front of the tube that is facing the center of ignitor.
also make sure that the air vent directly behind the knob is fully open.
Mar 30, 2009 | GE 30 in. Profile JGP979 Gas Cooktop
Gas cooktop problems
there is a part in the cooktop called a spark modual. it controls all the ignitors when it goes bad that what it does. replace the modual to fix the problem
Nov 25, 2007 | KitchenAid 31 in. KGCS105 Gas Cooktop
Ignition keeps clicking
the spark modual is bad and needs to be replaced
Nov 25, 2007 | Thermador 37 in. CEF365CS Electric Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
General Electric Monogram® ZGU385NSMSS (Gas) Stainless Steel Cooktop Logo
120 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
