Question about Hayward SAND FILTER, PRO SERIES
Replaced o-ring and still leaking around the collor
    Top Expert:
  • Hayward Master
  • 7,905 Answers
Make sure to use filter lube and make sure vertical pipe is straight if crooked seal will not seal correctly
Posted on Jun 05, 2016
Water leaking around water filter
Filter housing probably has a cracked or bent o-ring. Put some food grade lubricant around the o-ring. If that does not help, replace the o-ring.
Jun 11, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Leaks
Besides the O ring you replaced, is there an o ring or gasket any other place around the filter, if not, it might be a cracked block
Apr 16, 2014 | Cars & Trucks
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
2000 impala red circle recessed in radiator is leaking replace repair? ect...
It seems that the "black bolt" is the bolt-shaped sheet metal around the fitting for your trans cooler line. If you are certain that your connection is good and the leak is coming from around that fitting then you will have to replace your radiator as the area around the fitting is probably cracked. Take a good close-up look, with an inspection mirror and a light, to try to determine from where the fluid is leaking.
Does your other line have an O-ring?
Nov 28, 2011 | 2000 Chevrolet Impala
My son replaced the thermostat and thermostat housing on his 2002 ford taurus. It is leaking from the bottom of the housing. What would cause this?
COULD HAVE DAMAGED RUBBER O RING TIGHTEN TOO TIGHT OR REUSED THE OLD ORING WILL CAUSE LEAKING.IF YOUR THERMOSTAT HAS PAPER GASKET INSTEAD O RING. YOU NEED TO PUT SEALANT ON BOTH SIDES OF THE GASKET.THAT WILL KEEP IT FROM LEAKING.IF YOUR VECHICLE HAD A RUBBER O RING AROUND THERMOSTAT REPLACE WITH NEW O RING DONT PUT PAPER GASKET IF YOU HAVE THE O RING SEAL.THE O RING DOES THE SEALING NO NEED PAPER GASKET.
Jan 13, 2011 | 2002 Ford Taurus
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
I have a oil leak in a spark plug chamber how do i fix it
REPLACE VALVE COVER GASKET AND O-RINGS AROUND EACH HOLE INSIDE VALVE COVER TO PREVENT OIL FROM ENTERING. LEAKING FROM SEALS AROUND VALVE COVER TO SPARK PLUG PORT GASKET OR O-RING
Jul 13, 2009 | 2002 Nissan Maxima
Hayward SAND FILTER, PRO SERIES Logo
27 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
