Question about Garden
Trimmer string for craftsman 172.745450 - Garden
steve_lima
  • 181 Answers
SOURCE: repair a weed trimmer, How to remove the starter clutch
down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
Posted on May 13, 2009
SOURCE: no spark,craftsman string trimmer
  1. Remove the flywheel cover and pull the ground wire off of the off of the coil...
  2. Check for spark...
  • If you now have spark you have a "short to ground" some where in the in the wiring
  • If you still don't have any spark you'll need to replace the coil
Posted on May 21, 2009
  • 46 Answers
SOURCE: change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
Posted on May 31, 2009
  • 41 Answers
SOURCE: No spark Craftsman 989.796060 32CC string trimmer
I believe there is a t20 trox screw holding the clutch cover on. Look down the hole where the drive shaft would insert. After you get that off, the clutch itself needs to be pulled off of the shaft. DO NOT BEAT ON THE END OF THE SHAFT. You may need a small puller to get it off.
Posted on Aug 02, 2009
  • 391 Answers
SOURCE: my craftsman incredi-pull gas powered
The rewind is sticking due to congealed grease, take the rewind off (as a complete unit) soak in hot strong soapy water pulling the string in and out to help flush the dirty grease out from around the pulley and spring. Once you feel it is cleaned allow it to dry and then apply a squirt or two of a dry lube like the graphite used for locks.
Posted on Mar 03, 2010
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
Replace fuel and primer line on craftsman 358-798470EM string trimmer
Try searching Craftsman Weed Trimmer fuel line on this site for numerous responses to this problem.
Aug 07, 2010 | Craftsman Garden
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Jul 20, 2009 | Craftsman 25cc Gas Line Trimmer
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Don't know how to advance cutting wire.
Did you try bumping the head on the ground? Also, the head could be dirty, keeping the string from feeding. Or maybe the previous owner tried putting a larger size string in the head. Check to see what the proper size is for your trimmer.
Both of these suggestions could cause this.
Jim
Jun 03, 2009 | Craftsman Garden
Change feed fuel feed line craftsman string trimmer
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
