Question about Panasonic MC-V300 Bagged Upright Vacuum
How to replace the small belt on mce3011
Where does the belt go
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Replacing a belt on the Riccar 8850...I see how the brush assembly will work with the new belt. But I don't see how a new belt will turn on the small rod extending from the motor. Is there a pully missing?
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Apr 04, 2011 | Riccar 8850 Vacuum
The small belt attached to the roll brush keeps slipping off. It's a brand new belt and the vacuum is only 1 yr old.
The small belt rarely gives the problem you describe. The larger belt can jump off if the belt is worn or if th roller gets caught on something suddenly.The belt should be replaced every 9 - 12 months. If your carpet setting is too low this will cause the belts to wear faster that the estimated given time
Oct 04, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Im trying to replace the belt but cannot find where to connect it
Vacuums are different.  Look for a small motor shaft within the belt's reach.
Jul 09, 2009 | Vacuums
7901-1 need to remove brush and replace small belt
Follow the manual instructions! You just pop a little tab on top of the vac above the wheel. It says someting about belt replacement.
Just be VERY careful...I made it harder than it was (not checking the manual) and pulled the roller off, breaking the plastic roller arm clamps. NO ONE carries them & they have to be ordered off the web. They are less than $3 but it will cost double that for shipping!!!!
Apr 11, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Wind tunnel, small belt is missing. Brush bar doesn't turn.
You don't say which windtunnel this is. Is it an upright or a canister? If the belt is missing, get a replacement and you should be o.k. The belt should be replaced yearly anyway, as a matter of routine maintenance.
Feb 28, 2008 | Vacuums
Hoover Self Propelled Wind Tunnel Turbo Powered 7600 The thin belt too loose
If this is a "V" belt, make sure the small roller that tightens the belt is ok and not jammed up. It may have to be replaced. Also if the flat belt is stretched at all, it won't work either.
Nov 18, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
23 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
