Question about Homelite Mighty Lite Lawn Trimmer
Please tell me if there is a fuel pump in string trimmers. I didnt think there was. Thanks!
    Sniper:
  • 79 Answers
No, the only "pump" is the primer bulb
Posted on Jun 18, 2009
    President:
  • 957 Answers
No, the fuel is drawn to the cylinder by the vacuum created by the piston going down.
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
I pulled the fuel filter out of my stihl 45 but the fuel line didnt come with it. How do I get the fuel line out.
it has to be removed from the top of tank. it has a gromit also they may come as one part in which case you just replace them.
Oct 02, 2012 | Stihl String Trimmer Air Filter 45 55...
Type of trimmer: Poulan Pro PP125 17-Inch 25cc 2-Cycle Gas-Powered Straight-Shaft String Have not used the trimmer in a couple years due to broken fuel line. replaced the lines today. The primer bulb...
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Jun 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Run time ,
you didnt say how old the item is if its under a year old take it back to the shop
Jul 23, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Trimmer dies when i switch to run
Your trimmer carburator is a bit gummed up. Get a bottle of carburator cleaner fuel additive and add it to the fuel in the tank and in the gas can. Be sure to follow the instructions so you get the correct amount of cleaner + gas. In just a few minutes you will notice a huge improvement.
please rate my answer as very helpful. thanks. Joe
Apr 22, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
String is cut always
first of all be carefull of what you hit with the trimmer string if you hit sidewalks and rocks or dirt it will cut it short also you might make sure the tensil strength is strong enough to withstand the abuse the trimmers being subjected to :-)
Jun 22, 2009 | Black & Decker String Trimmer Cordless 12"...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Homelite Mighty Lite Lawn Trimmer  Logo
49 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
