Hard start I have an 06 ford f250 and it runs so good . How ever about a week ago it didn't want to start up . It whipped over for like 3-4 minutes then started. when it starts it runs great no smoke no nothing all is good . and if I shut it off and start it right back up it will start back up like it should . Its only if it sit's for more then 5- 10 minutes that it don't want to start up . hot or cold don't seem to matter . Thanks George
    Top Expert:
  • 25,737 Answers
Check for air leaks in the fuel pipes.
Posted on Jul 09, 2017
ilragatzzo78
  • 241 Answers
SOURCE: astro starting problems
your battery is about to die....
Posted on May 21, 2008
chiquititas
  • 1010 Answers
SOURCE: 1997 ford crown victoria starting problems
Sounds like you're on the right track. A bad TPS and ISC motor sensor will cause the problems you're experiencing. Your ECM relies on the readings it gets from the TPS to be sure there is enough air getting to the engine. If the ECM gets a bad reading and thinks not enough air is getting to the engine, it will cut the fuel supply, hence causing your engine to die. Your ISC relies on the reading from the TPS as well. It detects from the ECM if the throttle plate is closed or not. If it thinks the throttle plate is fully closed, it will start allowing air to enter the engine and bypass the throttle plate. If your ECM starts seeing some unmeasured air coming from ISC and detects the throttle plate is open (which it may not be due to a bad TPS reading), the ECM will again cut the fuel supply to avoid the risk of detonation.
So, replace your TPS first and see if that cures your problem. Also, check the resistence readings of your ISC to be sure that is within spec. If your problem still occurs, check your Intake Air Temperature (IAT) sensor in your air filter housing. Be sure your spark plugs, plug wires, and distributor are all in good shape as well. Replace your fuel filter if you haven't done so in the past 2-3 years.
Posted on Jun 23, 2008
SOURCE: runs ,then loses power after driving for 30-60 minutes.
AIR IN THE GAS TALK
Posted on Aug 06, 2008
SOURCE: reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Posted on Nov 22, 2008
alicantecoli
  • 22326 Answers
SOURCE: 98 Escort Hard starting when hot
sounds like a dodgy mis reading of a sensor caused by electrical resistance which is turning choke on and flooding engine.know the fault but without car in front of me its difficult to diagnose,could be auto choke sensor which is on right hand side of cylinder head ,but not sure.best is probally dealer have you tried spark plug gaps ??25th although this would cause problems with cold starting not hot starting but its worth a look
Posted on Nov 28, 2008
Diesel troubleshooting
I have a 2006 ford f250 diesel, It runs like a top . But when I shut this thing off it does not want to start back up . It will but it whips over for like 3-4 minutes and it whips over fast then starts . when it starts it runs great all the power is good and no smoke or anything . it don't care if its hot or cold it don't like to start. but if it only sit's for a minute or two it will fire right back up . It will only do this if it sit's for more then 5-10 minutes . Ok people any thoughts I would love to hear them. thanks George
Jan 06, 2014 | Heating & Cooling
1996 F250 powerstroke 7.3L keeps dying
It is sometimes difficult to determine exactly what is wrong with the 7.3L engines. Many times it is hit and miss for the do-it-yourselfer. It sounds like you are getting enough fuel at first and then fuel is being constricted. You might want to try changing the fuel filter. Sometimes debris becomes lodged in the fuel tank switching valve which would require cleaning the valve or replacing it.
Jun 13, 2010 | 1996 Ford F250 Crew Cab
93 ford f250 7.3 ltr diesal hard to start in cool or cold weather often run battery down have to recharge battery to start. new glow plugs installed 3 years ago. once started good for the day. warm weather...
This engine 'loves' glow plugs! One goes and the others try to handle the amps. Change them and you will have no probs! Other than that, I feel this is about the best diesel truck made!
May 21, 2010 | 1993 Ford F250
My 06 f250 only has heat when the truck is at high rpm
Sounds like the vacuum leak check all your lines
Jan 31, 2010 | 2006 Ford F-250 Super Duty
06 f250 6.0l hard starting, have to spin a long time, skips
with proper scan tool check FICM fuel injector control module main power should be 47 volts key on engine off 47.5 engine running if not replace FICM it has an internal problem also there may be a reflash available for drivability issues at the ford dealer this is not uncommon for 2004-2006 6.0s. keep me posted goodluck!
Aug 18, 2009 | 2004 Ford F350
06 Ford F250 won't start
Ford has a 100k powertrain warranty on their diesels... You can get it fixed at Ford if it's part of the powertrain...sounds like it is...
with a simple deductible payment of 100 bucks... well worth it.
May 30, 2009 | 2006 Ford Super Duty F 450 Drw
2001 F250 V-10 loss of power
hi i would check catalitic converter first thing good luck
Apr 29, 2009 | 2001 Ford F250 Super Duty Super Cab
1995 Ford F250 tail lights will not come on
incase you havent got it yet,check the wire whip under the back of the box under where the tailgate is,there will be a whip that is taped together with splices inside,uncover the wires and inspect them,they like to corode right there and ive done this before after hours of searching
Apr 19, 2009 | 1995 Ford F250
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
