Question about Samsung Office Equipment & Supplies
Lexmark z568 wont power up.
Why wont my lexmark 3300 printer not turn on?
Have you confirmed that the power source is pumping out the correct voltage/amps with a voltmeter, too? I'm assuming you meant that you verified the power outlet works?
Jan 02, 2015 | Lexmark International Lexmark 3300 Series
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
Lexmark x7350 vibrates and wont print
Hi
Try unplugging it from the power supply and leaving it as such for a while.
Check through the paper paths for any obstructions.
Clear any print queues.
Mar 02, 2012 | Lexmark X7350 All-In-One InkJet Printer
How do I unlock my Samsung A 501 mobile phone
There are many ways to unlock your mobile..But i suggest codes..This is the easy and safe method of unlocking compare to others..If you wanna code, get it from your network provider or you may get it from online providers like Wickedunlock.com .They will help you to unlock your mobile instantly..It's a permanent unlocking solution..
Sep 29, 2011 | Samsung A501 A801 A707(SYNC) A717 A727...
My lexkark x2600 wont turn on.all power is connected.
This article in the Lexmark website on The Printer is Not Powering On might help resolve your problem. If problem continues, please don't hesitate to contact Lexmark technical support for additional assistance. Thanks.
Feb 24, 2011 | Lexmark X2600 InkJet Printer
Lexmark x1270 printer wont turn on
If you are looking at the back of the printer, just to the right of the USB port is where the power cable goes. ( o o ) <--- Kinda looks like that but vertical, not horizontal as I drew it. Hope this helps.
Jun 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark poering out!
sounds like either a bad internal control board, or a bad power supply..power supply is easier to check..voltage needs to be as specified on back of power unit
Apr 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer wont turn on
power supply could be toast...unplug it..let all systems rest for a few minutes..try it again.
Feb 08, 2008 | Lexmark X3350 All-In-One InkJet Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
