Question about Eskuche 45b V2 Dj Headphones - Black - Black
Eskuche heaphones repair
The headphone cable is broken near the jack.
Marantz sr3053 stuck in headphone mode
Usually the headphone jack is like a mechanical switch and it's probably just not making a good connection inside. Use the correct size headphone jack and insert it then remove it maybe a couple of times and see if that fixes it.
Apr 18, 2014 | Marantz SR8001
You hear one side if I move the cable to the sides and sometimes sounds the other hand I think can be a cable cut
It's a broken wire, obviously. it's probably broken near the jack or the headphone. ur going to have to replace the cable
Mar 08, 2011 | Skull Candy G.I. Consumer Headphones
The wire cover is starting to come away from the headphone jack. I'm very nervous that the wire could easily break. What should I do? thanks in advance
Replace it before it does! See my tip on replacing dodgy plugs/cables on heaphones. You will find it by clicking my name.
Nov 27, 2010 | Bose TriPort Consumer Headphones
The jack has come out of its housing how do i fix this
Nov 26, 2010 | Skull Candy Skullcrushers Headphones
The wire disconnected from the jack, but the rubber wire protector still connects the two. How can I fix it?
Nov 24, 2010 | Sony MDR-XD200 Consumer Headphones
Broken heaphone jack inside desktop
Contact manufacturer of computer. If you have a warranty they should be able to help you with the problem.
Jan 27, 2009 | Dell Dimension 8300 PC Desktop
My pioneer djm 600 mixer has a fault where the headphones are not playing properly though each ear and doesnt sound quite right it is not the earphones
do some cleaning in headphone socket by apply spray contact cleaner in it----then insert headphone jack in---out many times after applying  the spray.
Sep 18, 2008 | Pioneer DJM-600 Silver Professional DJ...
Creative Zen Mirco 5GB
sounds like the ground or common has broken or cracked on the headphone jack. It shouldnt be a big deal unless its a broken Printed curcuit board or flex cable. Contact http://us.creative.com/support/custsup/a... for a sevicer near you. Good Luck
May 07, 2006 | Creative Labs Zen Micro MP3 Player
Eskuche 45b V2 Dj Headphones - Black - Black Logo
46 people viewed this question
Top Eskuche Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Eskuche Audio Player and Recorder Expert? Answer questions, earn points and help others
