Question about Zanussi Refrigerators
Unpacking zanussi fridge
Do i remove the white card n the top and back?
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
Zanussi Fridge ZC345R.How do I access the thermostat? I want to change it
just removing a cover
http://www.ransomspares.co.uk/diagram/zanussi/fridges-freezers/321903/zc345r%20%2892728266000%29/
Sep 15, 2015 | Zanussi Refrigerators
Just had a candy fridge Cfle 5485 w and as we unpacking it notice the back has a black seal. Is this just a transport packaging or should this be removed when using.
your question is not clear, better attach a picture. to be safe, if it is no bother for you and you do not see the back, just leave it there
Dec 24, 2014 | Refrigerators
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
How do I replace the thermostat switch on a Zanussi ZCE 7701CH? I have removed the screws for the side panels at the rear but cannot access the screws for the side panels at the front. The Product No...
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 18, 2011 | Zanussi ZCE7551X Electric Kitchen Range
Zanussi frost free fridge freezer leaking water at back
Here is a link for your unit's manual: http://www.serviceforce.co.uk/pdfs/U30164.pdf
May 15, 2009 | Refrigerators
Fan is rattling on zanussi fridge freezer how can i get at it or ny suggestions as to what the problem is
might be ice on the fan.....when its completely frozen your fridge part will stop working.
Feb 28, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
