Canon irc3220 e020-01b0 - Office Equipment & Supplies
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
E737 canon irc3220
There's no 737 code in error codes for that model,There is 747,which means main controller fault
Aug 08, 2014 | Canon Office Equipment & Supplies
Can't get my canon irc3220 to print please help
Call the service center number located on the label near the power cord.
May 24, 2014 | Canon Irc3220 Color Copier, Network...
E000110-0210 CANON C3220-C1
Code E110-0210 Description The operation of the laser scanner motor is faulty. The rotation of the M laser scanner motor is faulty.
The motor lock signal remains in an unlock state for 1 sec or more while the laser scanner motor is in operation. Error Codes Canon iRC3220 Code E110 0210
Oct 29, 2013 | Office Equipment & Supplies
Canon irc3220 E000020-02A0
E020 fault with drum / developer
the magenta drum needs replacing
xx=01 : y
xx=02 : M
xx=03 : C
xx=04 :BK
May 20, 2012 | Canon Office Equipment & Supplies
The image is shifted on my canon irc3220, How do i fix it ?
you can collebrate the image on copier so that image will not sift.
Apr 07, 2011 | Canon Office Equipment & Supplies
How i can get into service mode for irc3220 canon
Try pressing the following keys,
Asterix (*)
2 & 8 keys at the same time,
Asterix (*) again.....
Apr 15, 2010 | Canon imageRUNNER C3200 Copier
Canon iRC3220 can print but not copy....
try re-seating the Ribbon Connectors between the Reader Controller PCB, CCD Unit, and the Interface PCB found in the Reader Unit. You can also try reseating the SD-RAM DIMM's on the Main Controller PCB.
If message is still appears replace the Sub Main PCB (FG3-2855-000)
Aug 05, 2009 | Canon imageRUNNER C3200 Copier
Cannot download C3220 to computers
try to visit the www.canon-europe.com download drivers your machine IRC3220 or CLC3220
Apr 16, 2009 | Canon imageRUNNER C3220 Printer
18 people viewed this question
jasbo
jasbo
