Question about John Deere Garden
My JD ltr 180 will not run with the seat safety switch engaged.
I have a ltr 180 riding lawn mower. It was cutting out so I replaced the switch located in the seat. Now it will only run when the switch is disengaged, in other words the only time it runs is when the switch button in not depressed. Exactly the opposite of the way it should work. I then replaced the brake switch and the pto switch. I still have a mower that won't run unless the seat switch is out and not depressed. Of course that would be fine if all I did was ride on it but when I engage the pto or blade it kills the motor.
  • jahlobsta
    jahlobsta Feb 05, 2012
    If PTO switch on john deere mower kills engine,run a jumper from BLUE wire on PTO switch to the YELLOW wire on headlamp switch,this bypasses safty switches and youe headlamp switch will now control the PTO
  • 1114 Answers
SOURCE: Started up...then died as if safety switch 18HP craftsman rider
On later models there are possibly three safety switches, one under the seat, one for the blade engage mechanism or blade clutch so the blades don't turn when the mower is started, and a neutral safety switch to make sure the mower is in neutral before it starts.
Posted on Jul 07, 2009
  • 63 Answers
SOURCE: shuts down in reverse
I'm not familiar with that particular mower but I'd bet it is a direct switch. Follow the shifter arm down and you should see a arm or button that arm contacts a switch when you put it in reverse. pull the two wires off that switch, put a wire in between to connect them and it is by-passed.
Please rate if this helps-
Posted on Mar 23, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
  • 21 Answers
SOURCE: husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Posted on Jul 27, 2009
Motor cuts off when transmission is engaged or mower deck is engaged
Lois, sounds like you may have faulty safety switch, start by checking the seat switch first. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test lawn mower electrical safety switches
LAWN TRACTOR REPAIR how to test lawn mower saftey switches
How exactly do check the seat and brake safety switch on my tractor...
http://support.mtdproducts.com/app/answers/detail/a_id/327/~/safety-interlock-switch-locations---riding-mowers
May 21, 2016 | Garden
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
Disable all lawnmower safety switches
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
How to test lawn mower solenoid
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 16, 2016 | Garden
My ride on lawn mower is cutting out every time i try to engage the cutting blades
Sometimes it is due to the ETHANOL fuel you are using. ETHANOL is attracting moisture and after a while it builds up water in the tank.
Jul 06, 2015 | Garden
I have a Bolens Model 13AM762F765 38inch cut 15.5 HP twin blade lawn tractor. It runs like a champ as long as I do not engage the blades or put it in reverse. It will stall if either of these two things...
Sounds like a safety switch. Just as there is a safety switch under the seat that shuts mower off if you get off seat while engine is running, theres also safety switches for, pto, drive, reverse, etc. I would get a multimeter and look for switches under chassis and test with meter for continuity.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 08, 2013 | Mtd Garden
What causes JD 260 riding mower to start dying when you engage the mower deck? It runs fine when you disengage the mower deck.
It's the safety system that causes this. There is a switch under the seat that should activate when you are sitting in the seat. The switch can come loose or fail, the mounting can break, or the wires can come loose - any of these would cause the "engine dies when I engage the mower deck" behavior. Lift the seat, examine the switch. Rmove the switch and keep the plunger in with a piece of tape. Fixed? Then it's just the mounting or adjustment. Not fixed? It's the switch itself or the wires or connectors to it.
Jul 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My husqvana lawn tractor starts well and the engine runs but when I release the brake or apply the cutter it cuts out. Why?
Most likely the seat safety switch or associated wiring is the problem. It's designed to cut the engine if you release the brake or engage the blades unless it detects your weight in the seat. Tip up the seat and make sure the safety switch under it has not come loose, and that the wire connections are on tight. If that all looks OK, take the switch off and put a piece of tape over it the plunger to keep it in the 'activated' position and see if the mower works that way. If that fixed it, you should replace the safety switch. They are just a few dollars. Hope this helps - if so, please rate my answer.
Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades engage,but stop after running for a bit.
check the wire at the clutch on the crank shaft end try spraying the clutch with P B spry
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mower won't run
Did you try jumping the switch under the seat? Why would the foot switch shut it down? If it is the switch near the foot and you can't replace, then jump it. But be careful this will disable saftey features. Hope this helps.
May 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
341 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
