Question about Canton AV600 Speaker
What cabels do i need to connect canton av 600 to my tv
My bpl tv model fcr21 is connected to cabel but not to settop box why ?
use audio vedio pins to connect with AV function on remote
Feb 12, 2015 | Televison & Video
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
How to connect to a tv
to connect your dvd player to the tv you will have to use a connect cabel check the tv u will see audio and tv in the put one at the other end of the dvd for the audio and tv and the other goes to the other end at the back of the dvd then turn your tv to av then u can use your dvd ok thnks .
Jul 11, 2010 | Philips DVP642 DVD Player
FD Trinitron WEGA KV-SW29M50 29" TV: I try to connect TV to my video player. I have two...
well the tv has more than one iput with wich you can view your dvd from and they are all labelled as video1 and video 2 please identify which one you are using then as you do the connection make sure that the yellow terminal from the tv is for picture and white for audio.make sure if you connect to video 1 then select screen option as av 1.
May 17, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Xbox seems to turn ok with no obvious problems.
your av cabels could be going out borrow a set from a frend to test it out to make sure befor you go out and buy a new one for no reason. if its not the cabel then try to plug it into another set of ports or another tv . to makse sure tgat its not the ports on the tv set.
Dec 17, 2009 | Microsoft Xbox 360 Console
No signal to tv
your av cabeles could be on the wrong setting try to change from hdmi to tv on the end of the av cable that goes into the xbox. if it still dosent work then try to change the imoprt slots or try your cabels on another tv to see if its your cables thats the problem if you get signal on the other tv then its your first tv. but if you dont your av cabels mite be going i sugjest buying a new set if the other options dont work
Dec 11, 2009 | Microsoft Xbox 360 Console
ANY ONE KNOW HOW CAN CONNECT THIS LAPTOP ACER 5570 TO TV TO SEE MY DVD I GOT THE CABEL NEED BUT IT S NOT WORKING
You need the TV set to the correct AV channel and then you will probably need to use keys on the keyboard to swap from the laptop screen to the external monitor (TV). On my laptop i have to press Fn and F4
Jan 20, 2009 | Acer Aspire 5610-4648 Notebook
UNABLE TO FIND THE CABEL CONNECTION ON THE TV.
This Plasma is a monitor only and does not have the RF input to connect the cable signal. You should use a cable box or VCR as a tuner and use the AV output from the cable box or VCR to the AV1 input to make it work.
Good Luck.
Jul 23, 2008 | Maxent MX-42XM11 Television
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Canton AV600 Speaker Logo
Top Canton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Canton Audio Player and Recorder Expert? Answer questions, earn points and help others
