Question about Garmin Nuvi 350 Car GPS Receiver
My gps doesn,t acquire satelite signal, reset does not help
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 07, 2009
Hi, Just opened a new 1490LMT. Can't get a satelite signal. Small red bar appears on left top corner. Also, I'm in Winnipeg and can't get the GPS to acknowledge Winnipeg. Toronto is on screen.
When travelling with your GPS it may take 20-30 minutes for it to acquire a satellite signal. For it to acquire the signal it should be stationary so when visiting the family or in the hotel leave it on you should get satellite lock.
Hope this helps!
Mar 10, 2011 | Garmin nuvi 1490T GPS Receiver
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
GPS Firmware Upgrade Popup
Easy problem to repair. Please see this link for repair assistance.
- Jim
May 28, 2010 | Garmin nuvi 350 GPS Receiver
My maestro 4050 stopped receiving a signal from the satelite
try the hard reset, set it out to the open sky for a few minutes (may take as much as 30 min) to acquire the sats
Jul 01, 2009 | Magellan Maestro 4050 GPS
Invion 4V106 w/ Destinator 8 - can't acquire satelite
Baud Rate change in DestinatorApps\Destinator\UserData\GPSTMC.ini
May 08, 2009 | GPS
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmnin C330 slow to acquire satelites.
Make sure you are not moving. This way it can triangulate better. Wait for it to recognize at least 3 satellites. Then cruise as you wish as soon as it is synced with the satellites.
Also, be sure that you are on an open field with minimal aerial hindrances.
Your problem is normal to all GPS devices. It does take time to acquire satellite signal.
hope this helps!
-levibit-
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
142 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
