Gas flow from tsank to mig ok no gas flow from mig to gun tipyou can hear gas blowing off in to machine under the cover
Check with soapy water, change fitting or line
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
SOURCE: craftsman welder
.04 tips with .04wire with .04 liner etc.........
.025 tips wire .025 wire with .024 liner etc.....
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
SOURCE: Welder not welding
SOunds like your ground is not connected solidly either inside the machine or at the ground clamp. Check to make sure the ground wire at the clamp is not broken then make sure the ground wire is connected solidly inside the machine.
SOURCE: wire broken off inside of liner in mig gun hose
about the only thing to do is take the gun of the unit ,place it straight in line on the floor or bench and try to hand feed the wire back the other way.good luck,this will be a lucky thing if it works.i dont understand how the wire broke off in the first place.
