Question about Hartell LTA-1 Sink Drain-Laundry Tray Pump
Running continuously. Is this a switch problem?
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
1999 GMC Yukon headlights will not turn off. These are not daytime running lights. I manually turn them on and off. Now in the off position they remain on. Had do disconnect my battery to turn off.
Bad switch or relay. Do this when the light are stuck on disconnect switch and see if headlight goes out also do this check for continuity at the switch both on and off if continuity with both replace switch
Jun 12, 2016 | 1999 GMC Yukon
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
My fiat Doblo cooling fan stays on when engine is switched off
A significant number of cars have an electric cooling fan supplied by a battery live rather than an ignition live because it is believed the cooling fan should be able to start or to continue running after the engine has been switched off.
Coolant will continue to circulate after switch-off due to thermo-syphon activity and it could reduce mechanical stress on engine components to continue cooling.
Some people modify the cooling system by fitting an additional manual switch to over-ride the thermal switch for use when standing in traffic, for whenever continuous operation is desired or to use in emergency should the thermal switch operation fail.
In the absence of such a modification that has been inadvertently switched on the fault will be due to a faulty thermal switch, a faulty or stuck relay or shorted wiring. Disconnecting the thermal switch should stop the fan and if it does it indicates the switch is faulty. The switch is mostly fitted into the radiator header tank but sometimes is fitted to the bottom tank or the thermostat housing.
Feb 28, 2015 | Fiat Doblo Cars & Trucks
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
Engine overheats. plus once engine running a green flashing light with a (s) on it.
#1. Check coolant level,(engine stone cold and not running) change to a new one if not done in last 2 years.
#2. Change thermostat to a new one, Honda thermostat only, also every 2 years.
#3. In the thermostat housing there is a "coolant switch A" you should have a plug going to it, unplug it and while your engine is running almost at operating temp, bridge 2 wires with a wire, your cooling fan/fans should come on, also check for continuity you should have no continuity when engine is cold and continuity when the engine is at operating temp.
#4. If there is no continuity when engine is at operating temp then you need a new "coolant switch A"
Let me know here, if you need more help.
Dec 27, 2009 | 1992 Honda Accord
Riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
May 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Repaired Husqvarna 41 chainsaw won't start.
Hi
The off switch of the chainsaw has to establish the continuity to kill the running engine.First check the switch with a measure apparat.Then check the continuity of the two wiring harness,sepparately.One wire is atached to the ignition module with a screw and goes to the off position of the switch.The other one towards the on position of the switch.Check the spring!
regards savumihai71
Oct 26, 2008 | Garden
Heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
Mar 29, 2008 | Computers & Internet
Hartell LTA-1 Sink Drain-Laundry Tray Pump Logo
57 people viewed this question
Top Hartell Plumbing Experts
Donni Steen
Tom Chichester
Are you a Hartell Plumbing Expert? Answer questions, earn points and help others
