Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
I have a schwinn missle fs and it has new batteries. i put the charger on it to charge and the charger light says it's charged but it's not. What could be the problem?
  • 29 Answers
I've never worked on a Schwinn battery-powered scooter, but I'll weigh in--I'd check that the batteries are properly connected to the scooter. The charger may be connecting to the batteries, which are charged, but if the batteries aren't connecting to the motor, you're not going to go anywhere.
The only other thing I can think of to check is for blown fuses. Good luck.
Posted on Jun 18, 2009
Battery charging and running issue
hi, you say you replaced the batteries , but there could be other factors involved here...
Firstly don't run it with the charger plugged in , you can damage everything ...
1. the charger socket or related wiring to the batteries is either faulty or too higher a resistance...
Regards
Rob
www.facebook.com/gewizrepairs
Aug 11, 2015 | Health & Beauty
How do you charge your schwinn missel fs?
Using the charger, connect to battery and wall outlet
Jun 28, 2014 | Schwinn Missle FS
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
Battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
Jul 16, 2009 | Transport Schwinn Rechargeable Portable ...
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
My schwinn scooter wont charge, ive just put a new rear wheel on it and now it wont charge, ive tested the charger and its fine???
Probably a wire disconnected. Check the wiring harness for loose connections, disconnected wires, dirty connections pinched wires, broken wires. Also check and add water to the battery if needed. Check the battery connections and fuses.
Apr 22, 2009 | 2004 Factory bike Chrono SM 250
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
Can't charge my e-scooter
ok you do not need a new charger. the problem is you let the battery get too low. the battery has to have a little bit of power left in it to send to the charger, if it dosent then the charger can't tell if there is rilly a battery hooked up or not. you shuld probubly get a new battery. or you can email me and i will tell you a few things you could try to jump it back to life.      wildnfuzzy@gmail.com
Jan 24, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn S180 won't charge
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
Mar 19, 2008 | Transport Schwinn Rechargeable Portable ...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
283 people viewed this question
Top Electric Cycling Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
