Question about Ovens
OVEN DOOR LOCKED - Ovens
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Door does not lock
How to Fix a Door That Won't Lock on a Self-Cleaning Oven ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Modern self-cleaning ovens have a locking mechanism to secure the door ... Replace the mechanical lock if you do not have continuity on both microswitches.
Why can't I lock the oven door when baking? ' ShopYourWay
www.shopyourway.com > Derek Austin > Questions
However, the oven will not allow me to lock the door while baking. ... other range that I am aware of does not offer a feature to lock the oven when it is operating.
Dec 28, 2015 | Ovens
Got error code F9 while oven cleaning in process. What does this mean?
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock.
The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode.
The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
9 out of 10 times the lock switch has failed.
STEP # 1 - Disconnect power to the oven!!
  • Step 2 Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
  • Step 3 Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
  • Step 4 Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation2_bing.gif. Repair wires as needed if defects are present.
  • Step 5 Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
  • Step 6 Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
  • Step 7 Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
    My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
    For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
    Below is from the owners manual for your oven.
    Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
    Oven set for delay timed cleaning Oven will start to self-clean at preset time.
    Press CANCEL/SECURE to return to
    normal operation
    Double ovens only: Other oven is on. Turn off other oven.
    May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    DOOR Locked Flashing
    check the interlock switch, can be some object has stuck to it...
    Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
    My oven is locked and I have a oven mitt inside how will it come out?
    control reading door locked?? or door just stuck in locked position, try turning off hte breaker to the oven for a few secs , reset nad see of the door lock mech reeales itself. if ** you can try to put the unit into a clean cycle, and then 5-10 secs after he door "locks" press hte cancel button. both ways will cycle the door lock/latch assy
    Mar 10, 2008 | KitchenAid Architect Series KEBC107KSS...
    Ge wall oven blinking door locked for days
    The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
    Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
    Ovens Logo
    14 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
