Question about Avanti Electric 20.0 Inch Range ER2001G
Infinite switch ER20016
Front large burner only on high
Ceramic stove top large element on high and won't shut off until turned all the way off
The range surface burner control switch, that the knob is attached to, needs to be replaced. The link is an example, as I don't know the model. They are mostly similar between manufacturers.
Range Surface Element Infinite Switch Part Number 3148952 SAME DAY SHIP...
Feb 03, 2016 | Frigidaire Kitchen Ranges
Burner surges
You have a faulty "infinite switch" and it needs to be replaced. Here is the switch to order.
Dec 01, 2012 | Magic Chef CES3760 Electric Kitchen Range
Right front burner stays on high
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 04, 2011 | Cooktops
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
I have a Kenmore Electric Range (Model C970-629934) and one of the large burners only works as high heat - doesn't matter if I set at low the burner gets blazing hot??
Nov 18, 2010 | Kenmore Kitchen Ranges
Right large burner cooks on high no matter what setting.
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Hotpoint RB787BHBB Electric Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Burner adjustment
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
Jul 21, 2008 | Jenn-Air Kitchen Ranges
Avanti Electric 20.0 Inch Range ER2001G Logo
16 people viewed this question
Top Avanti Kitchen Ranges Experts
Lawrence Oravetz
Dave
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
